Yep we've been chatting for a bit.
He's given me a login to watch the auctions but obviously I'll get better results committing and giving him the finders fee.
I have a really hard time doing that knowing I can't inspect or drive the car.
Pass on that purple 33 imo.
There's a cheap white one for sale in WA. Light interior though.
Info is a bit slack but I'll copy paste for you as its only advertised on Facebook.
R34 GTR V-spec
$55,000
1999 vspec
Z tune front end.
Built engine. Still twin turbo.
515hp tuned by Fabcar
97xxxkm's
Pm for more info.
11062081_10207083009904707_8979728572263
11822437_10207083009624700_3951376446009
11828835_10207083008744678_7776055844256
11873537_10207083010264716_4435040795012
Edited by 10 4
Nice car, but prefer something that is Silver o Bayside with dark interior.
I can get away without the interior as that's easy to swap in, external colour is another matter.
WA is miles away too =\ Why is there so many 34s there?
OK update time.
Gun metal R34 guy called to say he's been pulling the front end down a little and can see signs of inner guard repair due to new seam sealer but said an inner guard only goes from radiator to strut on the GTR not the firewall.
Said he and the panel beater are happy with how it was done (he's a mechanical engineer) and that I'm welcome to inspect and photograph myself.
He said the same for radiator support but he couldn't spot any signs of removal for the cross member but did notice the lower radiator support was also replaced (whatever that's called).
He said he's less concerned after inspecting but thanked me for alerting him.
He also noted that the auction report he was shown displayed an auction grade 4, so bs.
Good to see select owners going that extra step, as it's likely news to them as well.
I'm a mech engineer to but I wouldn't know a thing about that haha - best to leave it to experts if you decide to pursue this one further.
Safe to say this one's still on the books for you?
It better be a shade of MNP or some Omori Factory treatment for that much. Or at least notably better than any local AUS example in that price range, to even consider.
Reminds me of a R32 GTR Iron Chef posted with an S1, R35 Brembos, R34 6sp transmission - arguably one of the best I've seen, around the $80k mark as well
Nope it was just a low k's vs2 in Ws2 and with mostly Tomei gear. Still standard bottom end but the full list of bolt ons and including things like endless frotlnt calipers.
Clearly a track car.
That's part of my issue is that 34s like the first one don't seem that common for the money (Inc all spares etc)
I could just play hardball and offer less, want all spares (as he talked about keeping the power fc) and if he says no, then so be it.
that requires a comittment of a days driving to inspect it though and the knowledge that I'll need a build sooner than I might otherwise due to k's
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
