Front has Cusco Adjustable top arms, 4 different settings... it's currently set to max negitive which should be about -2.5 deg, can get -3 to -3.5 I think if you also get an accentric bolt / bushes up there.
Flip the plate on the arm and you'll get a bit more.
Max the castor untill you hit the gaurd, then back it off.
+2mm total on the front toe
Neg 1.2 on the rear
-1 total on the rear toe
  • Like 2
Yep
Pretty sure you just rock up and call the guy and they'll unlock a garage. I'll try and sort it out beforehand though. If you PM me your phone number and bring some cash on the day I'll make sure to keep a space for you.
Probably also handy for any repairs that can be done with hand tools - couple of us will be bringing our tools.
Ok guys,
Who will be there on Sunday so I can make sure we bring enough steaks! Also SAU will have a garage for people to chill out in / get out of the weather.
Matt Lowth
Potato
Simone
13 Crag
Wog
Alex
Gav
Aaron
Birds +1
Darren
Borci88
Phantc_15
srs14t
Crzy32
Anyone Else?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
