Want to beef up the ignition system on my R32 RB25DE+T running all the usual stage one mods..
Currently running factory coils over gapped NGK plugs...
Theres 2 worth while options..
Aftermarket Coils (Ultra-Spark, YellowJackets etc..) OR A waste spark setup KEEPING IN MIND THIS IS A + T ENGINE.
I would opt for aftermarket coils if it was a regular DET engine but because of the turbo conversion I am wondering if waste spark is the way to go on the basis that it fires twice, once per bang stroke one per suck stroke..
Whos had experience with running different setups? What works best with the +T engines?
All info appreciated! :)
Cheers again guys
https://www.sau.com.au/forums/topic/460415-waste-spark-vs-coils-for-rb2025t/
2 points.
1) The ONLY replacement coil packs worth considering are Nissan and Splitfire. Use others at your own risk.
2) Wasted spark has NO advantages, and only exists because OEMs were cheap bastards looking to get multi-coil on the cheap.
If you want to replace the coils more completely than using original type coil packs, then the GM truck coils are the sensible option.
All this has been covered literally to the death (as in on and on and on for so long as to bore us to death) on here.
  • Like 1
Have u got pics or info on botch ones?
There not botched, Im just running factory coils atm which work fine but theres a little misfire, quality aftermarket coils can help the RB engine run smoother, Ive seen the difference between standard and aftermarket coils a few times and quality aftermarket items seem to always work better, Ive seen a few waste-spark setups which work fine too
Edited by Paulusc44
Quality aftermarket only seem to work better than genuine coils as the genuine coils there compared to are 20 years old, never seen the slightest hint that bolt in aftermarkets perform any better than new oem. The ls coil is a differnt thing all together though
A couple things:
1) the only coil set up (and I currently run it) I would even consider is the Delphi D585 coils (also known as LS2 truck coils, yes American V8 coils). These coils are the hot sh*t in the custom world as they are verified to put out more joules than just about anything out there on an actual Oscilloscope. Not marketing, BS, rumors, "oh my buddy's cousin's sister runs them," actual energy readings. Mojo performance makes a COP bracket for a reasonable price for the RB26 I know. I think he offers for the 25 as well, but go to his website and ask. I think the Audi R8 coils are also supposed to be pretty good but I haven't seen any ACTUAL data on them, just hearsay and I know they fit well. Spark energy aside, the audi and ls2 coils are good ideas because they get rid of the crap factory ignitor.
2) waste spark means absolutely nothing. it's just a coil firing concurrent with another coil firing. it does nothing for the other cylinder (that spark event is "wasted" hence the name). It allows you to run an engine on 3 ignition drivers instead of 6. If anything, wastespark reduces the effectiveness of your ignition because at high rpms, your coils could potentially run out of dwell time between spark events. that is basically not going to happen but it's the only event in which wastespark/sequential ignition may make a difference. Don't confuse this with sequential injection which IS a big deal. Your stock ECU already does sequential ignition and injection. Don't mess with it.
Oscilloscopes measure Voltage not energy? I would be very surprised if it would read the secondary output current accurately without blowing up, no matter how it was measured. Sounds like hearsay to me, I want to see the youtube clip.
better price and he is in AUS http://ls2rb.com/than mojo . I went with the D514a doe
A couple things:
There's some photos of my Bosch setup - sorry for the delay!
The coils are Bosch HEC715. I bought 6 of them (brand new) from Microtech on Gladesville for $225.00.
Only issue with them is that they don't have an inbuilt igniter so you gotta get them setup through an external igniter.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
