yeah definitely not lol i'm not that silly.i'll take the fuel line off and see if anything comes out. i'll probably just change the fuel lines but im not sure how to go about that.where would i get the hoses from etc. i assume i follow the fuel line back from the fuel rail and it go's under the car back to the fuel tank ? i'll google it tomorrow just having a guess for now
i just thought of a use for the fuel injection cleaner.if i disconnect the fuel line at the rail would it clean the lines and just spray out at from the fuel line ?
lol..anyways. im going down to supercheap auto soon to pick up some oil. should i get some fuel lines while im there ?
i had a look on there site.
this is what i found http://www.supercheapauto.com.au/online-store/products/RSP-EFI-Fuel-Hose-5-16-Per-Metre.aspx?pid=104897#Recommendations
how many metres would i need?
Getting the car to run, and getting the car to run right are completely different worlds, too.
Even if this car was running, and SEEMING to be okay, you'd still absolutely get it checked to confirm what seems okay, is actually okay.
As someone said, fuel, air, spark. It's gonna be a guessing game as to which part of the system isn't functioning but every system is pretty much testable.
As ben said... Car off the road for 3 years, and NOW super impatient to get it going?
3 years.
^This.
If I had a GTR sitting on my lawn, i wouldn't of been able to let it sit for 5 mins without trying to work out what was wrong with it. You've had the patience of an ignorant donkey for 3 farken years, a little longer isn't gonna kill you. You should really try and get someone with some sort of car knowledge to give you a hand b4 you make a shit situation even shitter. Good luck with it, I hope u get it running without too much hassle. Just being real.
impatient might of been the wrong word.over excited is more the wording i should of used. im just excited to get it going and i really think it wont be too much trouble.i think the battery was a main culprit for it not starting. fully charged it wasnt even at 12 volts. its sitting just above 10 on the gauge in the car.and it drops quite a bit when cranking. i tried cranking it earlier with the jumper charger battery ( with the fuel plug disconnected ) and it sounded like it wanted to start even with no fuel supply. didnt have time to check for spark and test the fuel injector plugs with a noid light,will do on sunday though. next step is to get a good battery!! and a new air filter since the one on there is filthy and wouldnt be helping.
next week im going to flush the petrol tank and with some injector cleaner but take of the fuel line at the rail so it doesnt go through the injectors, then i'll put on the fuel filter, change the oil and oil filter. chuck in some spark plugs etc. and try crank it. with fresh petrol obviously. then ill check if its getting fuel pressure.
also have a basemap on the ecu since i updated the firmware on it with the laptop,had a gtr basemap on there. also noticed when the key is turned to on that that tacho go's up in rpm then drops down. feature of the ecu? lol never seen it do that before.
really don't think its going to be that hard to get it started.
i'll take some videos of each step i take too( testing spark etc.)
also checked all the fuses,in the engine bay and under the dash and all were good.i thought there was fuses in the boot but i could not find them at all !!
Going to buy a new battery this Sunday or Monday. Really appreciate some input. I've been looking at some batteries but not sure which ones will fit since it needs small terminals. Best one I have found that will fit for sure is an optima yellow top D51R-T1D51R-T1 but is it really worth paying 225 dollars when it's only 450cca? Is it enough? I like to be on the safer side and get a slightly bigger one if possible. Let me know
im pretty sure thats the battery that i have now..and its shithouse lol its only 330cca .i would rather pay an extra $100 and get a good battery. i want one with a decent cca rating that will fit. i'll pop into battery world on monday but i want to get some ideas of good batteries and good prices for those batteries. dont want to pay more much then $200 if possible. $250 is the limit to spend on a battery
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
