Trust me. It is big enough. Why have a mahoosive battery in your car? If you need to grind the starter until it is flat, then you actually want another battery and a set of jumper leads to bolster your capacity, rather than carrying around an extra 10kg of lead.
You will not need to spend $200 either. I just put a bigger (like 560cca) Century into our Subaru and it was only ~$180.
i put on a jumper leads and it made a difference.which is why i know i definitely need a new battery. and on the voltage gauge its only showing 10 volts and it drops when trying to start ( didnt watch it when i was cranking with the jumper leads , was in a rush) another thing i was thinking is maybe alternator is screwed or maybe bad wiring/grounding. but i'll try a new battery first since i need a new one anyway. i think i'll settle for the optima D51R-T1. been reading good things about them and alot of guys recommend it. its $225. not that bad really and it has the right size terminals etc.
450cca is enough i guess.was being abit paranoid spending that much and it not being good enough. i dont want to go century again just because i didnt have a good experience with the one i had and alot of people say they're cheap and not that great where as optima generally gets alot of praise tomorrow i'll be testing for spark and testing injector plugs.i'll make a video and chuck it on youtube for anyone actually interested lol
Id say your jumper leads are farked or your earth is bad.
Last year i tried my new jumper leads and got nothing, i had 2 neighbors pull out theirs and still got nothing, i went and picked up a home made set i built back in the early 80's from some old battery cable i had left over from a boot battery relocation and it started.
Tested all the first lot of cables again and they still didnt work.
You would be surprised how modern jumper leads are crap.....had me wondering how many people have been through this and ended up changing their starter motor thinking it was the culprit. :)
jumper cables were fine..was using a jumper battery charger kit. it was cranking over with that hooked up to the shit battery. without it the voltage dropped completely when trying to crank it and it didnt make a sound. so battery is stuffed ( charged it the day before too )
i've ordered my new battery. hopefully pick it up in a few day :D
was just having a little play around with the gtr testing to see if all the lights work etc.
noticed big drops in voltages when turning on lights,indicators etc. actually it killed the battery in 5 minutes. now i know the battery is shit, but it was fully charged. is it just the shit battery or something else cause the voltage fluctuation like bad wiring/earthing ? i wont have my new battery till Wednesday to check if its because of a shit battery. when i had the indicators on with the lights on aswell,the brake lights would dim,electric windows barely went back up .
hope its just a shit battery and not shitty wiring ;/
that's the exact answer i was hoping to hear lmao can't really test anything now untill battery arrives. was going to install my fpr but the screws threaded on the stock fpr . piece of shit screw driver !! know idea how im going to get that off. the fpr i got looks shit anyways i think i'll try for a refund :/
i mostly just got a fpr for the fuel pressure gauge to test fuel pressure if im honest :S i thought what the hell.
been sitting for 3 years cause i haven't had much work in that time. i had no idea what to do with it until i recently got sick of seeing it sitting there and started reading up on how to get it going.i wont be able to get it on the road until i've found a steady job but i have enough cash to get it started atleast.... unless its in worse shape then i thought but i feel positive about it..for now lol
I wouldn't trust the gauge on a cheap FPR to be better than +/-5psi. Almost total waste of time. Fuel pressure best measured with good quality gauge teed into rubber line before rail. Easy, accessible, takes 2 minutes, 3 extra inches of hose and 3 hose clamps.
i suppose so.
had a quick play around today before it started raining :( took the cas off and turned it to see if injectors were firing. all of them were but the 2nd and 5th injectors weren't as loud as the rest.not sure what that could mean but my battery is shit so i dont know if that would have anything to do with it. i took out only 3 spark plugs since it started raining and couldnt continue. only the first one had spark and the other 2 didn't do anything at all. all the spark plugs looked the same. coil packs look fine to me but i wouldnt know what a bad one would look like. so maybe bad coil packs ? also im not sure how well the igniter was grounded so i;ll check it properly tomorrow if its not raining. or might just wait till i get my new battery since it was killing the batter really quick from turning the cas.
so question for today is, what does it mean if 2 of the injectors were nowhere near as loud as the others ? shit battery have anything to do with it ?
and whats the go with the spark plugs ? coil packs stuffed? or spark plugs stuffed ? i have a multimeter now but im not really sure how to use it.i had a search on google but my attention span got the better of me
just had another quick play around but stopped cause the battery is sitting at the 6v on battery gauge. using the same coil pack and same spark plug that gave spark on the first cylinder ( or whatever cylinder is closest to cam gears) i tried the first 4 cylinders . still get spark on the first cylinder ( very faint ) and no spark on the other 3 after it. this was using the same coil pack and spark plug just swapping it to the other plugs. im pretty sure its just cause the battery is shit. but is there any other possible causes ? i would of tested the last 2 but didnt see the point since battery is shit.
im not doing anything with it now. i thought it would be ok to try with the jumper starter but that needs to be charged its self.
should get the new battery on Thursday then i'll test it properly,
how would i check the coil loom ? visually or use multimeter ?
Both. Take it out, inspect it. Make sure the wires are good. Make sure the pins in the connectors are in place, not pushed back, not corroded, broken, whatever. Test with multimeter for continuity from end to end of each wire, etc etc. Same with injector loom. By this stage you'll probably be at the point of doing a comprehensive dismantle of the coils and injectors for swap-arounds and/or cleaning anyway.
Search the forum for instructions on testing coils. Cleaning, sealing, etc.
Got my battery today. Much better now. I tested same coil pack and plug on each Plug and only first one fired.... Then I I out in the stock ecu and they all worked! So I guess I'll have to read about the vipec ecu to configure it.wont change spark plugs for now. Getting fuel now and going to see if fuel comes out from the fuel line. Do I disconnect it after the fuel filter?oh and I'll change the fuel filter while I'm at it
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
