Hey guys. So I bought a 1994 R32 GT-R. Car drove amazing when I first got it. It only has 84,500 km's on it. The weekend of the week I picked it up. I decided to do a service which entailed:
. Oil
. Oil filter
. Air filter
. Rocker cover seals and half moons
. New front brakes
. Fuel filter
. Iridium spark plugs
The car already came with splitfire coil packs.
After driving for a couple of days, I noticed my car started to have a bit of a stutter. Wasn't bad. Few weeks later I went for a drive was stuck in traffic for a bit then when I started to drive it started to misfire severely. It started to sound like a wrx. It was a warm day but it never used to do that. Took it to an auto electrician tested everything possible that could cause a misfire and everything was getting power. Did a comp test all cylinders had the same reading. Changed coil packs and spark plugs and it still does it. When it's first started and driven it's fine. As soon as I drive for 30 mins it starts to miss. Even if I have short drives, turn it off start it again it struggles at idle thwn revs pick back up. I lose alot of power and is super sluggish!
Any ideas on what it could be?
https://www.sau.com.au/forums/topic/460506-misfire-issues/
Did you throw out your old spark plugs? Try throwing them back in - my first ever mistake when I bought my car was my initial home service... I didn't gap the spark plugs properly.
Also try doing a warm compression test and leak down test immediately after it starts shitting itself...
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7624602
Yeah see i threw my old ones out. I put iridium ones in. I took them out to notice that one of them was cracked.I put cheap ngk ones in because that's what was in it originally but it still stutters and sounds like it's choking! The compression test I did was hot. Was making compression fine! Do you thibk I need a bigger gap?
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7624738
Do the AFM solder fix.
This. Search the DIYs for it.
BTW opening up the plug gap makes it harder for the spark to jump, so if you're troubleshooting a missfire at max torque you would close it up.
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7624802
That happened to my car before massive pain in the ass can't even get my hand on it that's how shit the spot is right up against the firewall on the intake manifold gasket about a 4 mil chunk spat out. best way to check is pump compressed air through the pipe work after the cold side of the intercooler and test for air leaks you hear it gushing out at the back at the firewall it's in a flamin mongrel of a spot it would be easier to pull the engine out and change all your gaskets at the same time to metal ones even head gasket would be worth doing while engine is out.
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7626919
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
