This thread is a train wreck. I approve.
Pics of RB20 coilpack setup.
Pics of compo received for the time (4 hours) it took to take maybe 10 bolts, some plugs and replace 6 spark plugs.
Edited by iruvyouskyrine
I bought a set of the same spark plugs just in 0.8 now it better fix it now i got a spare set of bcpr7es -11 if anyone want to buy $10 let me know only 100km used. Btw if this doesnt fix it im gonna link it hard
f**k YES i figured it out and it was the MOST STUPID REASON WHY!!! YOU WILL NEVER GUESS...
are you ready....?
ONE OF THE f**kING SPARK PLUGS WERE CRACKED INSIDE THE CHAMBER BECAUSE I MUST OF OVER TIGHTENED IT!!!
REALLY?? AND GUESS WHAT, as i was putting one of the new spark plugs in, I ALSO CRACKED ONE. So i put one of my old spark plugs from before i did the service back in. So tomorrow im gonna have to go buy one more spark plugs
f**k me im stupid, who would of thought tightening these spark plugs would make the white part crack??
seriously i wasted $50(coilpacks) + $60(coilpack loom) + $35(new set of spark plugs)+ the time spent travelling and the labour.
Learn this lesson from me, NEVER overtighten ANYTHING!
  • Like 1
You didnt crack it from overtighting it, you cracked it because you didnt hold the socket straight at some point while tightening.
If your holding the spark plug properly and tighten hard enough you will strip the threads in the head and the porcelain part will still be fine.
  • Like 2
this.
i was using the extension bar and it moves around the socket a bit. I got up to the third cylinder before i cracked it. I hope i didnt over tighten the first 2 cylinders...
a rubber insert in the long socket helps keep the spark plug central and will avoid cracking.
my god i have one with a rubber socket but i didnt use it, i think because the spark plug didnt go all the way in or it would get stuck in it.
When putting new plugs in, bottom the plug out in the hole by hand with a extension, then tighten 2/3 to 3/4 (max) of a turn extra.
So run them in till they reach the end, then tighten the last 2/3-3/4 turn more.
Just use your left hands fingers to keep the extension centered while the right hand turns the extension.
  • Like 1
man i feel so stupid because i even cracked one of the new ones and i think little bits of plastic fell inside the head....someone please call me stupid
because it would make me feel better :glare:
Stupid,stupid,stupid. You asked I delivered. Feel better now :)
  • Like 1
i'm pretty sure some awesome dude who knows heaps about european porn...I mean, cars...said
"spark plugs don't like being dropped. A cracked ceramic insulator can cause ignition issues"
spark plugs are one of the few things I use a torque wrench for, would suggest you do the same until you get the feel for them, or follow gtrpsi's guide above.
i'll also just say, I like your attitude, seriously. You were prepared to have a go at it...ok, f*ked it up, but, acknowledged your mistake and have learnt something in the process. As long as no major damage caused, not a bad result at all. Although, I you're seriously concerned bits of ceramic fell in the cylinder and you haven't run the car yet, pull out the plug and use a vacuum hard up against the hole, vacuum out any bits of insulator in there.
are you ready....?
Lesson is if it was fine before you touched it, then it's you.
It's always easier to blame everything else first though.
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
