No worries, I'll take some pics over the weekend and post them up.
I bought the car over a year ago (March '04) and had it stored at a mate's car yard over there. Unfortunately the turbo seezed up completely because the engine wasn't run for such a long time. The Turbo's only a watercooled T2 though, same as on the late model (87+) ET Pulsars, so it wasn't hard to find a replacement.
Even without a turbo the car still had plenty of torque up to around 3000rpm, after that the supercharger turns off (it has a clutch on it) and the car doesn't run too well without a turbo :-)
I saw a MA09ERT motor a couple of years ago, someone had put it in an EXA Turbo. It seems the engine has the same mounts as an E15ET, in fact the block looks very similar apart from the tiny pistons/bore inside it.
My plan is to swap the bottom end for one from an E15ET, bigger injectors and a T25G off a CA18DET, bob's your uncle, instant stroker from 990cc to 1500cc. Might need aftermarket management but I'm expecting big things from this little car!
The exhaust is truely tiny, either 2" or maybe even 1.5", so that can definitely do with some improvement.
The car is Active Green, I was going to respray the car when I saw the picture of it in Japan, but I've changed my mind, I reckon it doesn't look too bad now that I've seen it in real life, fairly unique colour anyway!
The interior is in very good shape, which is a bonus. It also has one of those old style sunroofs that you can either tilt up or take out completely, even a bag for the sunroof is still in the trunk :rofl:
  • 4 weeks later...
www.justjap.com has a white one in their Cars In Stock section.
Description: 1988 NISSAN MARCH K10 - $7,999 990CC, Supercharged/Turbo, FWD, Manual, 23,000 Km's, 6 months rego
If anyone buys it, I bags a drive in it as a spotters fee!
hey,
  We have a super turbo on our yard..
  cool pc - correct me if i'm wrong but isnt the e15t a 4 cylinder?
You're gonna have seriosu difficulty bolting that block to the super turbo as its only a 3 cyl  :whatsthat
Cheers, Paul.
The MA09ERT is a 4 cylinder. #4 is sort of hidden under the intercooler but it's a four cylinder.
The standard turbo is a Hitachi HT10. Since it is not a normal Garret T2 flange it is not possible to fit a GTIR T28 turbo. I had a custom T25/HT10 built for mine, the exhaust housing is very restictive, but I have helped this with a custom 2.5 inch straight through exhaust. I wouldnt dare try any more boost with the tiny intercooler and engine internals. However I plan to build a 'big' power MA09 soon. Aim is for around 200wbhp :);) Its mad enough already though, at the first sign of wet roads wheelspin will result if you go WOT in 3rd gear!
The standard turbo is a Hitachi HT10. Since it is not a normal Garret T2 flange it is not possible to fit a GTIR T28 turbo. I had a custom T25/HT10 built for mine, the exhaust housing is very restictive...
Hehehe... reminds me of my friends old Honda City turbo. The turbos were tiny on those things and not easily upgradeable, so the only alternative was wind 2.0bar into it :)
  • 3 weeks later...
Im almost certain that the March that JustJap have (unsure if they still do), is a Turbo, not a SuperTurbo. I had a look at it one time when I was there.
I was actually looking for a turbo/supercharged kei car or similar to use as a runabout if anyone has one lying around.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
