Just now, K-LESS said:
Please feel free to correct me if I'm wrong but it's almost like a piggy back or a Apexi SAFC but it's for your Throttle and sits between that and the ECU?
Yep, thats exactly what it is. Just changes the signal.
  • Like 1
The problem is, its very easy to go too far and the car can't be driven at low speeds because the throttle is so sensitive. So it takes a bit to find the happy medium. It has like 40 preset levels which is dumb. It also has an eco mode which is like the car is being pushed by 4 midgets.
  • Haha 1
I'm guessing it's still an alternative as opposed to forking out big money and re-tuning and re-calibrating computers and things etc. Still cool how they still use and do such things.
  • Like 1
3 hours ago, Dose Pipe Sutututu said:
I still apply a slight damper on it, so it's not so sensitive, which I assume most don't.
Fair enough. I guess the important thing is that you are in control and can set it up the way you want it. Which makes a big difference I would think.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
