Next month I'm about to pull the pin on some 2860R -5 but have some question about the marriage between the turbos and my engine. The old bird has done 197,000km and she runs quit well. She is stock and only has an exhaust and PFC as mods. I'm just wondering if these turbos are going to kill the engine or are there supporting mods I can do to make the union work without a catastrophe or is there a safe boost range to work within?
https://www.sau.com.au/forums/topic/461537-save-my-rb26/
Its all in the tune. If you are worried you can do a compression and/or leakdown test but there is no way you can get more power from your engine without increasing loads. The amount of boost is irrelevant - either you want more power or you don't. Plenty of people have increased the power on their unopened engines - some last for years some don't. The only thing you can do usefully is use quality synthetic oil and get a really good tune.
  • Like 2
https://www.sau.com.au/forums/topic/461537-save-my-rb26/#findComment-7650236
Pretty much what Kiwis4t said.....
If the leakdown and compression test come back good, some good oil and a good safe tune is all you need. (and supporting injectors, fuel pump etc)
Edited by GTRPSI
https://www.sau.com.au/forums/topic/461537-save-my-rb26/#findComment-7650251
fuark, mine's a mint Edward Lees R33. Shows 149xxx but body says it has about 350xxx.
Rust was hidden with sound deadening, motor had leaks on rear main seal, front main seal, cam covers etc.
Did all the maintenance work and now sees 23 to 25psi err day stock motor and gets raped on the track, albeit it's a shit box GTS-t so yours being a GTR you have no worries.
https://www.sau.com.au/forums/topic/461537-save-my-rb26/#findComment-7650407
Who's Edward Lees?
awesome car yard in Sydney that can supply any car with the kms you want lol.. they simply wind the clock back to what you want and tell you they've found this mint car from Japan LOL
I personally didn't buy my rust bucket from them, but the previous owner did!
https://www.sau.com.au/forums/topic/461537-save-my-rb26/#findComment-7650420
I'll take kiwi and johns advice on board Thx for the suggestions.
The reason for my concern is that I read somewhere that -7 and -9 place less stress than the -5 and that the smaller turbos would be a better choice for an engine that's travelled further. Don't know if the information is good but by the sounds of things seems as though ppl here are quite optimistic with the strength of the RB 26 lashing out the power regardless of Km's.
https://www.sau.com.au/forums/topic/461537-save-my-rb26/#findComment-7650446
MotiveDVD guys have their stock motor R32 GTR making over 450kW at all fours with only new headstuds and a head gasket.
These RB motors love it.
https://www.sau.com.au/forums/topic/461537-save-my-rb26/#findComment-7650454
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
