Item: R33 GTR Nismo intercooler (part number14461-RS580) 270 x 600 x 100 core.
Price: $1,800
Condition: Second hand but very good condition. Was on the car for roughly 10,000 kms
Payment: Direct debit to my account, Or cash on pickup (if in Sydney)
*Pics of cooler are coming. I just need a chance to take some.
Item: Bosch EV14 2225 cc injectors (set of 6)
Price: $500
Condition: Flowed up fine. Needs baskets if you want to run them ($6 each). In the car for roughly 5,000 kms at a guess
5BBD9D0F-04D3-466C-8AE8-145818AC7BC0_zps
Item: Garrett – 5 turbos.
Price: $1700
Condition: Used for 10,000 kms. Going single so no need to them anymore.
These have had the turbine housings ported out to match the gasket, rear housings have been ceramic coated and Ive had the actuators modified by Racepace. This increases the leverage on the arm. Currently set to 19psi but have had them at 24.
449FE644-C725-452A-A4CD-3D56595A3C8E_zps
Photo of modified actuator arm.
37B88D82-C051-4CF1-A2DB-AB1561CCC5F4_zps
Photo with gasket overlaid.
5E62BC2E-0E66-4206-B1DD-0A10763492DF_zps
Item: Tomei Series 1 dump pipes
Price: $ 550
Condition: Fine. Have been ceramic coated
D5089FF2-37F4-4BC5-8040-4ADEA54F4005_zps
Item: Racepace twin 3 inch exhaust system
Price: $3,200
Condition: Fine. Few scratches here and there as you would expect. This exhaust was made by the previous owner of Racepace for his own car. As far as I know, it’s the only one they made. It’s a shame to let it go but won’t really work with the single setup. Front pipes (which are tuned length) have been ceramic coated also. Made 472 RWKW on -5's on Unigroup's dyno. No restriction here.
Underbody shot of exhaust on the car.
From rear of the car.
It would, I believe with an ever so slight modification. You're welcome to try it.
33/34 is the same bar 20 mm.
Item: HKS AFM delete pipes
Price: $150
Condition: Fine. I sprayed them black to look more "standard".
Payment: Direct credit into my account, Or cash on pickup (if in Sydney)
*Surge tank not inlcuded :P
83747408-BDED-481D-A4E9-C644DF3AA119-142
How they look on the car.
Ive done quite a few k's in piggies car & i also pulled the racepace exhaust off his car.
I can tell you its a well made unit and fits like a glove!
This exhaust sounds horny as hell!
Ive gotta say its not exactly the quietest exhaust on idle but somehow its volume really doesn't change that much when you're up it!
Dont have to tell you all this is a rare 1 off exhaust system that will make your R sound fat as hell!
Now hurry up and buy this thing so Paul can give me the monies to make him a new exhaust! :D
  • 1 month later...
  • 4 weeks later...
  • 3 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
