yep if that op6 has a nylon wheel on it get a coke can and take the shaft space up with that so your steel or alloy wheel will fit snug as, if they leak which all the nissan ones do
run fuel straight through it run the return back to tank, it works a bit like an extra injector, and will throw a top grade flame out of the exhaust, i was thinking that op6 you have
will ya swap a house and land package for it, gee wiz it sounds like it goes, and i wont ever have to fix a motor again with that op6 turbs, forget the v8 to complicated
i got a starfire at home twice the power and strength, if ya still not sure about no 5 but its running ok take the plug out and poor ajax down the plug hole always
fixes bottom ends thats what the best machine shops use
dont shot it that wont fix it, dont get mad just get ya good mate to fix her up
Wow you guys on this forum really are f**ked hey, you guys look so retarded its like theres a room full of you faggots holding each others cocks taking a turn at a typo war (long term forum faggots vs rb30t) sounds like you all have a lot of baggage & hate from your previous f**ked up inexperiences with cars ha ha, down to the point where its easier to writes masses of junk hating then a sentence of being helpful.
I fixed the problem weeks ago without your help.
Oh thats rite im new to the forum youd better gang up on me n hate cause ive never seen that before or fixed a car...........................not
Peace fools
  • Like 1
Peace fools
100% back you up on that.....
Peace fools
Nah mate I am serious, I couldn't understand wtf was being said, sorry to offend but I was only saying the truth.
So did you use ajax to fix the problem because I am really interested to know what you use ajax for to find a problem with an engine. How did u fix the problem anyway?
Can you please type it in point form so I can understand it because obviously I am not accustom to comprehending modern modified English.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
