Did not expect this:
Jolyon Palmer stays put at Renault in 2017.
Renault Sport chairman Jerome Stoll says:
“The line-up of Jolyon and Nico harnesses the benefits of continuity and fresh blood,” Palmer said.
“I am sure that having Nico as a team-mate will help push Jolyon to greater achievements.
“We thank Kevin Magnussen for his efforts in 2016 as he has done a great job for us this year. We wish him all the best for 2017 and beyond.”
“We have been impressed with his increasingly strong performances on track as the season has progressed.”
“We are confident that the combination of Jolyon and Nico Hulkenberg offers a very promising driving force to meet our goals.”
Yeah but to be fair he appears to have been getting better and the better of Kevin lately.  Goes postal on the radio which is always amusing.  Magnussen is supposedly off to Haas.  Guessing he got pushed.  Still happy for the Hulk after all this time he may have got a properly good seat.  Will see how much coin and how good the Renault is next year I suppose.
Reckon Britney will win another race this year?
If I was Hamilton I would have done the same thing, re backing britney into vtool, it was his only option to take the championship.
Congratulations to Nico, he had the right combination of skill, luck and equipment, good on him.
Edited by Missileman
19 minutes ago, Roy said:
God let Button get the call back to McLaren and let Alonso walk due to performance clauses!!!!
+1 that would be some entertaining racing I would love to see. Jenson would probably be gagging for the seat too
This is true, but he doesn't have to carry on the way he does.
This is the thing that I like about Rosberg. He is much more.... Professional I guess. All these reports coming out now that Hamilton was going to walk away from Mercedes blah blah blah. As if you would walk away from the best car on the grid mid season.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
