Qld Raceway Sprint Track - 59.30 sec
Qld Racway Clubman Track - 1:02.25 sec
Qd Raceway National Track - 1:25.61 sec
Can anyoen clarify the number of circuit formats you guys use up there...it seems i have made a mess of the times as i didnt realise there was 3?!?!?! Is there more?
This was from a *very* long time ago:
SAU Nickname: 46n2
Car Make and Model: R32 GTST
Circuit Name: Qld Raceway, sprint circuit
Lap time: 1:07.78
Modifications
Engine:RB20DET
Power: dyno'd at ~110rwkw a few months before before hitting the track
Suspension: HKS non Adjustable coilovers, Front Hollow Swaybar
Other Mods: None - stock right down to the exhaust :D
Tyres: Ventus (cheapo rubber that came with rims) - useless with no grip
Brakes: RB74 Front, rear standard, rotors standard
First time with new setup
SAU Nickname: Stealth
Car Make and Model: R33 SII GTST
Lap time: 1:00.95
Modifications
Engine:RB25DET
Power: dyno'd at 347hp atw
Suspension: Tein Adjustable coilovers, Nismo Swaybar
Other Mods: Race pipe, GT35/40 int w/g turbo, intercooler, PwrFC,
Tyres: Bridgestone Potenza RE540s
Brakes: bendex ultimates Front, RB74 rear, rotors standard
__________________
Updated Winton time - 4.5s off my previous PB to a 1.35.2. Very happy. (updated original post)
Mostly due to upgraded brakes and modified transfer case. Anyone with a GTR that's keen on track work the upgrades to the transfer case is one of the best mods I have ever done to my car.
ahh I got to knock 1 sec of my wakefield time today, but I am cheating now :D
SAU Nickname: Duncan
Car Make and Model: 32 GTR N1
Circuit Name: Wakefield
Lap time: 1.10.2
Modifications
Engine: Standard N1 spec
Power: tba
Suspension: some jp coilovers
Tyres: Dunlop DZ02G
Brakes: standard
Body weight: 1460 wet
ahh good question that was Andrew that has made transfer case mods, I assume more clutch plates? personally i reckon the controller acheives the same end but I would have to try em back to back.
How is your additional block ventilation mod going?
andrew what did you do to the transfer case? and mind telling me what pressures (HOT) to run the RE55 tyres :D
I was at wakefield on saturday.... however had oil catch can issues! hmmm back there on the 11th to try again!
how do we go about timing for the no speed limit days?
cheers....
Duncan guessed right here. I've never used the controllers but I have been told there are some advantages of the transfer case mods over the controllers - how marginal the difference is I'm not sure so like Duncan could only tell with a back to back trial. But god damn through the tight stuff it's made a huge difference.
Ben - I run my RE55's at 30psi hot.
:rofl:
duncan now all you gotta do is drive a 31 round the track. here is chris' effort
SAU Nickname: Chris
Car Make and Model: HR31 GTS-X
Lap time: 1.12 (something decimal pointish)
Modifications
Engine: R32 RB20DET
Power: 160kw from last count
Suspension: HD Coilovers
Tyres: turanza or some e30 stuff
Brakes: R33 4-pistons at front, R32 at rear
Body weight: 1400
Actually Chris was doing some great laps considering the drives a POS 31 :D but the tyres he was using were dunlop D01J. Hope he makes it to the drift nats in Adl OK :)
I was out there last monday, Powerplay had a private track day and I took the opportunity to give the car a final shake down before the state champs at Oran Park this weekend. It ran great except for the cracked rear rotor so I should be out there OK.
We found with just the controller, it would get some slip towards the end of a race and the oil temps would climb rapidly. No slip with the additional plates, last the whole race and lower transfer case oil temps all the time.
:goddam: I had better ring around and warn everyone.
PS; Only kidding :innocent: good luck.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
