Isnt that the same move Beer Baron "pulled off" on his R32?
Shame to see it happen! Any cause known for the other one catching fire?
Well, not to appear vulture like, it looks like it has had a major bottom end failure and sprayed oil all over the engine bay, ignited on the exhaust and took off.
A few guys on track stopped and helped to put it out. About 6 extinguishers all told. If the guy is on here, it's only money - just fix it and get back out there.
Ouch thats no good
Although its good to see others helping out :)
SAU Nickname: Cain
Car Make and Model: Nissan 350z
Circuit Name: Mallala
Lap time: 1:23.68
Modifications
Engine: TT kit
Power: 300+ rwkw
Suspension: Bilstein pss9
Tyres: Falken RT 615
Brakes: Project Mu BBK
Body weight: 1500kg
was havning an issue with the car going on limp mode near the end of the day when i was going flat out on the rear kink.
SAU Nickname: R33line
Car Make and Model: R33 GTS-t series 1
Circuit Name: Wakefield Park
Lap time: 1:10.78 min
Circuit Name: Oran Park south
Lap time: 53.51 sec
Modifications
Engine: F/M intercooler, pod filter, 3 inch exhaust
Power: 220 hp
Suspension: front coils
Tyres: potenza semi slicks
Brakes: RDA rotors, EBC red pads
Body weight: 1450kg
PIARC yesterday - 1.48.4 -just too much traffic with 24 cars on track and being released pretty much at the same time.
Tried to follow Sam in his thing, but lasted the length of the front straight on the out lap - wicked machine.
The 1.47 will have to wait for 2 weeks.
Good work Andrew...any footage? New tyres or old? I think once you, Ant and Ferni drop below the 49s thats it for me for having anyone i can play with :)
Yes, have some that I haven't cut up yet. Prob do that tonight.
It wasn't my PB - did a 1.48 flat last time - so close it's frustrating.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
