Meant to be me. I got persmission about 8 weeks ago and slowly going through the thread from back to front noting times in a spreadsheet to update. Probably another 2-3 weeks away
Ouch, that would take some time to do then. Need to have a form that is filled out/posted to make it easier to do. There is 61 pages now!!!!
Put me down for a 1:03.81 around Wakefield when you get through it all if you can.
Gee wiz you getting fast, is this in a S14 chassis?
Did you have a R32 then hello kitty now this?
You are thinking of badhairdave.
He still has hello kitty, but its sitting around gathering dust like my sil80 is. We both need to get out more
Ryan, think your were down at PI when i did the gearbox? Yes it's a S14
http://200sxweb.blogspot.com.au/
Sorry bud I was not there but you might be thinking of Troy in the blue S15!
Nice blog too BTW.
Are you competing in WTAC?
what qabou
yes you do!
come out and try beat my dry time in the wet again!
  • 1 month later...
SAU Nickname: ls128
Car Make and Model: R32 GTR
Circuit Name: Eastern Creek North Circuit
Lap time: 1.18.196
Modifications
Engine: RB26DETT
Power:240kw stock boost garret -5s etc
Suspension: HKS coilovers
Tyres: 255/35/18 Federal RSR Semis on the front, same size federal 595s on the back
Brakes: stock
Body weight: 1450kg? stock weight?
http://www.natsoft.c...09/2012.SMPN.S1
Number 21.
ended up boliing my brake fluid! New brakes soon me thinks..
Edited by ls128
am I the first at SMP South?
SAU Nickname: you know who I am....
Car Make and Model: 1994 hairdresser 5
Circuit Name: Sydney motorsport Park South
Lap time: 1:06:1
Modifications
Engine: intake, headers, exhaust
Power: around 80ish rwkw
Suspension: Tein coilovers, whiteline front s/bar and bishes
Brakes: RDA sloted and and QFM pads
weight: I dunno, 950ish?
tyres: v70a
was done today @ Festival of sporting cars in Marque and Productions sports cars race.
qualified 7 out of 19
looks like its a track suited to gay cars like mine.
  • 1 month later...
SAU Nickname: Iplen
Car Make and Model: 32 v-spec II
Circuit Name: Wakefield
Lap time: 1:11 ish ;)
Modifications
Engine: 20psi, n1s, pods n' pipe
Power: whatever that adds upto..
Suspension: Ohlins bought second hand on here
Brakes: Project Mu club racer fronts.
Tyres: old re55s, one had "over 100 laps- stuffed" written on it
The time was in traffic, and hand timed, so this is more reference for the future..
  • 1 month later...
http://racing.natsoft.com.au/636317781/object_7760768.88Y/View?5
SAU Nickname: MLR
Car Make and Model: 33 GTST
Lap time: 1:10.6330
Modifications
Engine: 25/30
Power: 380ISH
Suspension: Bilstiens
Brakes: A1RM DBA4000
Tyres: Hankook RS3
Late update but is my PB.
  • 3 weeks later...
SAU Nickname: szymonsta
Car: DC2 Integra Type-R
Circuit: Mallala
Lap time: 1:23.05 (myChron Lite TG)
Modifications:
engine - standard B18C7, MBit exh mani,WedsSport cat, Fujitsubo exh, Mugen N1 ecu, Mugen sump, Koyo rad
118kw @wheels
suspension - Zeal Function Xs, Vision adj camber arms
brakes - endless rotors, endless na-r pads
tyres - RE55S
  • 4 weeks later...
  • 5 weeks later...
Barbagallo Raceway
Circuit Distance - 2.41km s
Short Circuit
1. Chris260 , R32 GTR - 54.98sec
2. djr81, R32 GTR - 57.1776sec
3. PSI_GTSII - R32 GTR - 58.98sec
4. Topaz, R32 GTR - 1:02.3269sec
5. ant95GTR - R33 GTR - 1:02.28sec
6. ant95GTR - R33 GTST - 1:04.9sec
7.
8.
9.
10.
Long/Full Circuit
1. Chris260 , R32 GTR - 1:04.9547
2. Snowman, EVO 8MR - 1.05.7sec
3. DJR81 ...post up your mods etc and car, R32 GTR - 1:06.73
4. DR30RS, DR30 - 1:08.2 sec
5. ant95GTR - R33 GTST -1.13.88sec
6.
7.
8.
9.
10.
Reference Lap Time:
- 1:07.15, GT Production Mazda RX-7 (2000)
Collie Motoplex
Circuit Distance - 1.60km s
1. Snowman, EVO 8MR - 0.51.3
2. Chris260 , R32 GTR - 51.38
3. djr81, R32 GTR - 51.69sec
4. Gav, R32 GTR - 0.53.4
4.
5.
6.
7.
8.
9.
10.
Car Make and Model: 1995 R33 GTS-t
Lap time: 56.4721 (Barbagallo Short)
Lap Time: 1.06.3858 (Barbagallo Long)
Lap Time: 51.3304 (Collie Motorplex)
Modifications
Engine: RB25DET with 2835 HKS turbo at 18psi
Tyres: Khumo V700
Brakes: Standard calipers, DBA4000 front rotors - Ferrodo DS2500 pads
Body weight: fully stripped and caged, approx. 1290kg with half a tank of fuel
  • 3 weeks later...
Date: 31/03/13
Circuit Name: Winton
Lap time: 1:48.3
Timing method: Natsoft
Modifications
Engine: RB26 with PowerFC, Garret -7s
Power: 325rwkw on E85
Tyres: Kumho KU36 245/35/18
Brakes: Stock with A1RM pads in the front
Body weight: Stock minus rear and passenger seat.
I dunno what I'm doing wrong but I was struggling to get much quicker. Practice make perfect i guess. Better brakes might help too as they were starting to die.
SANDOWN 1:14:79
http://racing.natsoft.com.au/635977201/object_12396208.91C/View?2
Date: 07/04/13
Circuit Name: SANDOWN
Lap time: 1:14.79
Modifications
Engine: RB26 with, Garret -5s
Power: 420 awkw on E85
Suspension: KONI,
Tyres: PIRELLI 305/645/18
Brakes: AP's front/rear
Body weight: 1290 KG DRY
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
