deprived777 Posted January 5, 2016 Share Posted January 5, 2016 hey, so just had my r33 gts-t tuned for the first time. these are the mods: 3inch custom turbo back exhaust HKS GT-RS turbo Nismo 550cc injectors yellow jacket coil packs ngk Bcpr7ES 0.9mm spark z32 AFM Nismo fuel pump Blitz return flow intercooler Apexi power fc Apexi pod filter Drift catch can Greddy sm integrate gauges (boost, oil temp, oil pressure, water temp, fuel pressure) Greddy EBC Car made 237kw at the wheels on 18 psi and just under 200 kw on low boost setting (12 psi) it was all good on the dyno but on the road using high boost it was misfiring horribly when booting it. Trent,who tuned the car mentioned that when he took it for a drive that it did misfire but then it went away and wasn't doing it. maybe its my driving but it was horrible when i took it for a spin. He said it might need better gapped spark plugs to help the coil packs and mentioned that yellow jackets are known for misfiring, which upsets me since i bought them less then months ago. Car drives great on low boost atleast but thats no fun at all lol Anyone else have similar experiences with yellow jackets ? could 0.8mm gapped spark plugs make it any better or is it worth begging for a refund for the yellow jackets and going splitfires ? Does 237kw seem a bit low for 18psi ? what could be causing it to be a bit down on power ? was expecting over 250kws to be honest from what i had seen on the forums i'll see if my scanner works and post up dyno sheets Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/ Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 5, 2016 Share Posted January 5, 2016 I cooked 2 out of the 6 Yellow Jackets I got, replaced them.. then kept misfiring, even with plugs gapped at 0.5mm... so I took them out in lieu of brand new Splitfires.. I now run upwards of 23 psi no misfire Buy either OEM or Splitfire or convert to LS coils or similar.. those colourful coilpacks are all junk (trying to avoid naming names) Also your lower power reading could be from your poor spark performance 1 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662211 Share on other sites More sharing options...
Ben C34 Posted January 5, 2016 Share Posted January 5, 2016 Heaps of people have had issues with yellow jackets. Costs nothing to drop gap, and see what happens. 1 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662212 Share on other sites More sharing options...
Trex Posted January 5, 2016 Share Posted January 5, 2016 Ask for a refund and move onto standard or splits. standards are only $50 more than the splits from kuosmotorsport. OR What plugs are you currently using? Did you change them when you changed the coilpacks? Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662218 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 thanks for the quick replies plugs that are in now are ngk Bcpr7ES 0.9mm i didnt regap them as i never done it before and it didnt want to stuff it up lol. They were changed same time as coil packs. i've emailed the place i bought the coilpacks from and asked for a refund so ill see what happens. ill be pissed if they dont refund me will i need a touch up tune when if i change coilpacks ? Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662243 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 5, 2016 Share Posted January 5, 2016 Bring it back for a check up, I'm sure Trent won't mind or ask for much extra. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662244 Share on other sites More sharing options...
admS15 Posted January 5, 2016 Share Posted January 5, 2016 Close gaps down to 0.7mm in the meantime. Shouldn't need a touch up if you change packs but never hurts to do check up Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662248 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 i'll have someone do the sparkies for me since im retarded at doing little things like that. and if that doesnt work i guess i know its 100% the coilpacks. so you guys recon i could gain a bit more power with splitfires if that might of been the limiting factor. apart from the misfiring the car drives fantastic now after the tune and cold star issues have gone and gained a decent amount of power on the dyno. can someone tell me why it wouldnt be misfiring while on dyno but misfiring while driven on the road ? first time i had any car tuned so new to all of this Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662252 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 here's the dyno sheets. really hoping i can get more power with a touch up with splitfires Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662281 Share on other sites More sharing options...
Cowboy1600 Posted January 5, 2016 Share Posted January 5, 2016 I had the same issue at 235rwkw. Gapped the plugs to about .6mm and it's sweet as. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662310 Share on other sites More sharing options...
Ryno Posted January 5, 2016 Share Posted January 5, 2016 (edited) I think you are aware of the problem (being the coils) and band aiding it by gapping the plugs down isn't really going to be a long term solution. Our setups are quite similar. Same turbo, computer, AFM, injectors. Though my car makes around 40 rwkw more at the same boost. I run Splitfires and only had an occasional misfire when using BCPR6ES plugs, but since changing to one heat range colder (the same as you are running) I've had no misfire issues. Edited January 5, 2016 by Ryno Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662346 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 (edited) whoa 40kws more then me, now i'm even more devastated lol would the difference in power be due to the bad coils/plugs? big difference !! i was expecting closer to 260 and was pretty disappointed with what i got. trent recommended NGK bcpr7eix gapped down to 0.55mm so ill give those a go and see if it improves. i wont bother getting a touch up tune till i can get splitfires put in. Really hope i can get closer to 260rwkws! Edited January 5, 2016 by deprived777 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662348 Share on other sites More sharing options...
Ryno Posted January 5, 2016 Share Posted January 5, 2016 Yeah you should make 260... I've got a trick exhaust manifold and run an external waste gate, which gives me an extra 20 kW or so and about 500 rpm better response. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662354 Share on other sites More sharing options...
breaker1845 Posted January 5, 2016 Share Posted January 5, 2016 Too many people care about numbers, just get rid of the shit Coilpacks, buy OEM or Splitfires as mentioned by everyone and enjoy the car. Get someone to gap your plugs down or do it yourself. You can buy a tool from super cheap auto. If there was no evident misfire issue on the dyno while Trent was tuning, then there will hardly be any power difference after the touch up. There are hundreds of other reasons why it could be down on power but not up for discussion now. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662366 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 yeah i'll get them regapped and go from there. but if i can be making more power then why not chase it.unless its going to cost a fortune then i'll leave it as it is. may be a number but in my mind 260 and over would make me happy lol i'll take out the plugs tomorrow and get someone to gap them for me. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662377 Share on other sites More sharing options...
KiwiRS4T Posted January 5, 2016 Share Posted January 5, 2016 If you can remove the coils and take out the plugs you can gap them. Just get some feeler gauges and there is probably a how to on the web if you can figure it out yourself. In fact just tap the plugs gently on a vise or something and keep measuring the gap. Sounds like you need new coils though. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662389 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 I did attempt to gap an old spark plug using one of those Rosen medallion type gap tools but it juat wasn't going right for me lol I'll look for a feeler gauge but probably be easier for me to get someone else to do it haha. Yeah I'm thinking coils too from the bad things I'm hearing about them. They sounded promising at the time and I was reading mostly good things but I guess I must of just been looking for the good things being said wish I waited and bought splitfire. I don't know of they'll refund me of not. Fingers crossed! Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662393 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 5, 2016 Share Posted January 5, 2016 They're good as paper weights. I only bought replacement ones because the car already came with them, after replacing 2x coils and still having misfires I just bit the bullet and bought Splitfire coils and haven't looked back. However if I could have a stab at it again, I would just convert straight to LS coils. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662445 Share on other sites More sharing options...
deprived777 Posted January 5, 2016 Author Share Posted January 5, 2016 i'll have a look into using LS coils. havent read anything on it to be honest. is it cheaper then going splitfires ? lol Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662541 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 6, 2016 Share Posted January 6, 2016 works out about the same, a little more dicking about.. but you'll have spark for days and easily run 0.8mm gap without any misfire at like 20+ psi. I got a mate who runs them on his SR20 and putting 25psi through the motor and he runs his gap at 0.8mm errday With Splitfires they tend to break down if you run 0.8mm at 20+ psi and with more dwell in them they will run ok till they overheat and start misfiring a little time later. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/#findComment-7662550 Share on other sites More sharing options...
