dont get me started on YJ's and performance China Racing wise lol. I think a few of you saw the shit storm on some of the products I and a few others had bought which do not fit.
FYP
  • Like 1
FYP
good call. fixed it myself too ;)
I HAVE to say; That certain supplier is worse than the producer, as they should have stopped importing certain parts. Anything to make a quick buck eh? Don't worry about stepping over anyone on your way there.
quick question ,what if you over tap the spark plug and the gaps to small. what do you use to widen the gap without damaging it ?
i have used a flat head in the past and was very careful to push it up.
I think you are aware of the problem (being the coils) and band aiding it by gapping the plugs down isn't really going to be a long term solution.
Our setups are quite similar. Same turbo, computer, AFM, injectors. Though my car makes around 40 rwkw more at the same boost.
I run Splitfires and only had an occasional misfire when using BCPR6ES plugs, but since changing to one heat range colder (the same as you are running) I've had no misfire issues.
I've got brand new Splitfires with BCPR7ES (I think, or whatever Trent told me to get). On 18psi I still had a misfire. Gapped them to about .6mm and they are all good.
I think you should be aware that results with coilpacks and plugs seem to vary quite greatly on RBs for some reason. Two people can have identical set ups but have two very different experiences. There's obviously something else in play, but plug gaps are the only known fix as far as I am aware.
before reading replies i figured out how to put the gap back up haha i found my round medallion tool and used that. i checked 2 spark plugs and the gap was 0.75mm ..they were supposed to be 0.9mm. unless im measuring it wrong but i span the medallion around carefully till it stopped moving and its where it landed.
i'll do the rest tomorrow so i can see what im doing lol
There's obviously something else in play, but plug gaps are the only known fix as far as I am aware.[/background]
Only known fix? There are several ways that could fix the problem other than gapping down the plugs.
It could be a poor engine or coilpack loom. Or the engine earth could be the problem. Also the connection to the spark plug within the coil pack and the coil pack plug itself could be the issue - though this is easily fixed by cleaning the coilpack and using dielectric grease.
By gapping the plugs down, you are trading off low throttle performance and economy, and the car will make more power through the rev range with the largest gap you can get away with running.
So yes everyone's engine is in different levels of condition, but I'd fix the underlying problem rather than living with gapped down plugs.
yeah im just gapping them down for a temporary fix, didnt realise you lose low throttle response though :( car is already poor on petrol lol lucky to get 300km out of a full a tank .
coilpack loom look looks like new from my untrained eyes.
coilpacks look very clean i took two of them off earlier, i didnt use dielectric grease though i'll lhave to look into that
I find they're ok on the dyno whilst I'm tuning, great for street use.. as soon as I hit the track and do a few laps.. bamm misfire city!
But at 0.5mm it's tits.. no misfires at all!!!
Interesting
My old splitfires died recently (this was not a gap issue, they were breaking down nearly on idle. Must have had at least 1 no good coil) so i have a brand new set in now
Might gap the plugs a bit lower next time to be safe. Although its only a street car and havent really had any dramas before on 0.8
Interesting
How long did they last if you don't mind me asking?
update on the ebay dude:If it is a faulty coil then it would only be 1. It wouldn't be all 6 at the same time.
This alone is an extremely rare occurrence as a lot of care goes into these coils during the manufacturing process.
We will need isolate the single faulty coil though so it can be replaced under warranty.
Thanks.
whats my reply going to be ? should i go for replacements or keep insisting on a refund. to me replacing them is more hassle and seems a waste of time if they're going to keep failing
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
