hey guys just purchased a 99 gtr vspec and am having an issue when i come onto boost starts at about 4.5k rpm and gets worse as u accelerate. it feels like im losing traction and the cars rear will kick out to the right. i plan to taqke it to the shop to get it looked at but was just wondering if anyone had an idea of what it might be. It may be something as silly as a boost leak or something, ive come from an sti and ive had boost leaks before doesnt feel anything like that tho car shakes and feels like its jerking back and forth throughout the rev range. car is completely stock no mods other than pirelli p zeros all round no engine work done. if i let the boost build up slowly it wont freak out and cause the problem only when i hit full boost it will start ripping up the tyres and sliding out. ive checked for boost leaks spraying on ic pipes etc but no luck so far locating the issue could this me a afm issue or something to do with the air/fuel raitos? the restrictor pill was removed by owner in japan and is running 1bar.
sorry if this was a silly question or has been answered elsewhere, i just cant put my finger on it!
(not trying to troll )
Edited by v-specjay
Have you considered that you are now driving a RWD biased AWD car and it could actually be losing traction at the rear simply because it is losing traction?
There may or may not be an alignment problem or worn bushes or subframe mounts etc etc that might be causing it. It doesn't HAVE to be coming from the engine end of the car!
If its standard as you claim it shouldn't be doing that.
But if its modded.....fully sik. :)
On a serious note, my GTRs rear use to come out under power, she would crab walk, ended up being the subframe bushes were leaking and i put some alloy C rings in place to stop it, she went straight after that.
Itsat standard vspec height its sitting on original suspension also yes it still has original coil packs. I will have to look into the subframe bushes hopefully something turns up..n yes gts boy i understand that its not a full time awd but this is not just simply breaking traction due to power from the rears its more like when i come on boost imagine like fuel surge bunny hops and makes the car break traction and jerks the car forward and backward similar to what youd feel when you have a large boost leak..soo frustrating!
It could be the ATTESA system that also activates the rear A-LSD on a R34 V-SPEC needs bleeding
Either way it sounds like the car has some issues, best off getting it to someone that knows these cars so they can give it the once over
  • Like 1
If boost (positive pressure) Is only coming in at 4.5K rpm on standard turbos you have issues... Are you sure this is the case as per your post???
**edit** i think i misread due to punctuation... You are on boost, then at 4.5K rpm you have traction issues
Edited by djvoodoo
  • Like 1
Oh i forgot about the fun bundle that the A-LSD is.
Ever experienced axle tramp?
  • Like 1
Yep the tyres are all the same size, i think it sounds like axle tramp, never experienced it before but sounds on par with whats going on with mine. Thanks guys and
  • XKLABA i will have to check out the attesa see if it needs bleeding. Could be a combo of all of these things just helps to narrow it down a little.
Cheers for the info guys ill report back after a once over from my mechanic if anyone is curious as to what the problem was.
If a stock R34 GTR is breaking traction it has a 4WD problem of some sort, or very very shit tyres, if it has a 4WD problem and is a V-Spec it will most likely have an A-LSD problem to
A small air pocket won't kick a code but will slow down the operation speed of the diff and 4WD
Lol. How can it break traction and jerk back and forth.
Axle tramp is like a hopping sensation in the back.
Sti and gtr are WORLDS apart in how they drive
yep im not exactly sure mate feels like a little of both at the same time im assuming it has something to do with the attesa ill take it to croydon see what they make of it
ye exactly it feels like the torque is being split up unevenly or delayed, i have a feeling your on the money.
Edited by v-specjay
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
