12654366_10154570666309386_4141860202374
SAU Vic MotorKhana #1 2016
- ENTER HERE -
http://www.sauvic.com.au/entry/motorkhana/20160221
Its time to get the SAU Vic MotorKhanas under way for 2016.
Always a popular event, these days are perfect for new drivers to learn their car in a safe environment and gives a place for the seasoned driver to hone their skills.
Our first MotorKhana is being held at Foresite Driver Training. Not only a great venue but close to Melbourne. This is a day that family and friends can come, watch and cheer as you speed around the test courses.
Entries are limited to 30 entries and cost will be -
Members Entry Fee $85
Affiliated Car Clubs Entry Fee $105
Supp Regs: http://www.sauvic.com.au/download/motorkhana/SAUVICMotorkhanaSuppRegs_20160221.pdf
Disclaimer: http://docs.cams.com.au/CAMS%20Forms/Events/Disclaimers/General%20Disclaimer%20-%20Participant.doc
Members with have a 48hr priority window for entry. After that the event will be open to everyone.
Entries will be open this Friday (5-Feb-2016) with more info on the day coming soon.
Entries -
Martin Sullivan
Simon Henman
Luke Schulze
Stephanie Atkinson
Kurt Thompson
Jeremy Blackman
Huy Phan
Sam Lehmann
James McDermott
Alex Roman
Gregory Kruse
John Packham
Glenn Dunn
Dan Madden
Nicholas Momirovski
Tim Wenas
Andy King
JC Pook
Kane Martin
Paul Richardson
Chris Starr
Shamal Perera
Ben Johnson
Ryan Thai
Joselito Da Rocha
  • Like 1
https://www.sau.com.au/forums/topic/462657-sau-vic-motorkhana-1-2016/
Entries now open to the public! Come along and join in what is always a fun day at our MotorKhana #1.
Click the link and enter away :)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
