Hello, i've recently done a turbo brake conversion on an n/a, all seals replaced and caliper bores and pistons cleaned before installation. but when i took the first drive there was a sound in the rear like fluid being forced out, upon stopping there was fluid on the outer lip of the disc and fluid all around the wheels, not enough to be dangerous but eventually. so i put it down to a faulty caliper as it had a speck or two of surface rust and replaced them with better condition ones, these have the exact same problem and im so confused, im assuming its the piston leaking but im hoping its the new HEL braided lines i installed as the 34 gtt lines have a little bit of thread exposed from the caliper
Any help would be really appreciated because i need to drive it and done wanna pay drug money for a shop to look at it
https://www.sau.com.au/forums/topic/462690-brake-fluid-leak-help/
Take your wheels off where it's leaking and clean the discs, calipers and lines with brake cleaner. Once it's all completely dry, start the engine and pump then hold the brake pedal a few times. Then go back to the brakes and have a look where the leak is coming from. You may be able to see if it's coming from the line itself, the connection of the line to the caliper or the piston.
The problem is it never leaks when the car is stationery, when it picks up speed and I brake there's the hissing noise and it spits fluid, but only when it's moving
There's a little fluid around where the line goes in but there's fluid on the edge of the disc aswell and I can't see how the lines could leak onto the disc
It doesnt make sense that it only does it when you're driving. Follow Dark26's excellent advice, just make sure you press the pedal as hard as you would when driving. Also don't discount that it could even be the new lines.
  • Like 1
I sat there and pumped it for a while and I can feel a tiny amount under the lines, so I'm replacing the lines, I agree it doesn't make sense but whenever I try it never gets at wet as I expect so I just dismissed it.
Still I'm baffled that fluid from the lines can make there way onto the rotor
If you pump it up a couple times how is it any different to braking while driving? The only difference is the pads are doing their job
It's not exactly different but you may be braking differently in your driveway than when you're driving. You haven't said how long you were holding the brakes in the driveway so I'm assuming that while driving you're holding the brakes longer for stops. If I went for a short drive for testing, I would probably slow down to almost stopped from 60 about 5 or so times by the time I make it back around from all the T intersections/corners I have to turn at. It may not seem like much but you may not be braking the same amount in your driveway as you do while driving, that's where I think the difference is. Try pumping the pedal a few times and then hold it down with firm pressure for about 10-15 seconds, if you don't notice anything repeat this a few times.
Well my current thinking is the lines, I did find paint flaking from the area and looked into whether the 34 lines are right for the conversion and it seems the 34 calipers have a much deeper fitting for the lines, I'm thinking this isn't making a good seal since half the thread is exposed
33 lines are ordered so we'll see if that's it because two sets of good Nick calipers failing can't be a coincidence
Are your new lines the same type of connection as the calipers? When I fitted some GTT brakes some years ago I had to convert from banjo to screw in type (or the other way round - can't remember now) and had to remove the olive from inside the caliper.
I think Bob's on the right track.
There are 2 fitting type, one has a flare on the end of the brake line with an angled end that seals on a similar angled end in the caliper (the "olive" Bob mentions). The other type uses a banjo bolt that seals with a copper washer between the head of the bolt and a (hopefully) flat part on the caliper where the bolt screws in.
If your brake line has the copper washer/banjo setup it needs to seal tightly to the caliper, and it won't be able to do that if the banjo bolt bottoms out on the original fitting before it is tight.
So to check that you can look at the copper washer; they are designed to crush a little when they are tight.
The stock ones didn't use a banjo bolt, just an unnecessary bracket thing, but they screwed in fully whereas the new lines have this hardline tube coming from the threaded part which stops it screwing in more than halfway
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
