Hi, just wondering if you have thougt about making ones for the gtt for the front fenders? Or if you have what style do you have? Cheers
Hi Michael,
I can machine up any style badge with any dimension you need, as for the GT T badge for the guards no probs at all. Havent drawn up the badge with the T but would take much time.
And as for the finish would be the same as previous posts in the thread, any type of finish or color inlay you need we could do it.
Cheers
See below ready to CNC machine, anyone interested in the GTT Badges send a PM and we will advise all details.
As in previous posts the badges will include
  • Either 1 x Boot Badge or 1 x Pair Guard Badges
  • CNC Machined - Polished finish with DNA Red Candy Inlay - Diamond Clear or Crystal Resin inlay
  • VHB Double Side Tape
Options can be either lettering without the base, black base or silver base.
Also have the GTA badges ready for cutting
Thanks
  • Like 1
whats the price for a GTR badge?
Hi Tristan,
In regards to the CNC Billet GTR Badge - What size were you looking for - Boot or Guard - or custom sizing
Which of the following options were you looking for?
  • Polished Lettering with Red Centre
  • Polished Lettering with Silver Base and Red Center
  • Polished Lettering with Red Center and Black Base
I'll PM when I have these details
Hey SAU
we have some more options on Custom CNC Billet Badges for Interior, exterior, guards/fenders, side skirts, boot, engine bay, etc....
Im also working on some lower level lettering rather than extruded letters.
these can be done in any size required - also with the following options
Any color inlay
Polished Lettering with Color - No Base (So the lettering and R will be as individual letters)
Polished Lettering with Color - Silver Base
Polished Lettering with color - Black Base
Cheers
  • Like 1
Hi mate, i like the gt-t badging you designed up and id be interested in a boot badge and gaurd badges.instead of the red insert are you able to do it in a carbon fiber look? Thanks
Hi Michael,
Thanks for your interest, I will try a sample with carbon fiber inlay and send some images through.
Cheers
Suggested by Michael on the previous post - Carbon Fiber - GTT Centre Inlay
This is the 3D version and will run some samples and get the images up for you all.
Note the badges will be CNC Machined Billet - with Carbon Fiber inlay clear crystal overlay - Silver Base - Polished Lettering
Hi. Yes i like that. Once you get a set made could you please let me know your price. Thanks again
Hi Mick,
Will surely advise the costing when we run the sample - hopefully by mid week we should have it completed.
It will be cut through tomorrows production run.
Cheers
This.
Do you guys do centre caps too?
We could machine wheel centre caps - the front face would be fairly straight forward with design work.
depending on the style because most are plastic and have the grooves with a spring tension ring to keep them locked in to the wheels
We have designed some wheel centre caps but we had the drawing provided and many manufacturers have different internal sizes. These were machined with a groove and O ring with an interference fit so they locked in pretty nice.
Another option was the anti theft design
I'll PM you some details needed RobZ
Gts30t?
GTS30t - we could machine anything you need with this incorporated - if you can advise if you want the size for the boot on the right hand rear side then we could send some designs to you.
I had a few requests for the GT R Style Badge but with the RB-25/26/30 - and also the RB25/30 Engine Ornament Plates
Yeah we could do many things with the Gts30t
Gts30t?
Put a few different designs together for the GTS Style badge - Logo
This would be for the rear drivers side of the boot - or anywhere you like I guess.
Custom size can be made to what ever your requirement is.
See below image - any part of these drawings can be altered changed modified before cutting
  • As always the Lettering would be semi or full polish depending on preference
  • Red DNA Candy Inlay - or any color
  • Clear Overlay
  • Double Sided Tape on back
  • Black or Silver Base
  • Can also supply individual lettering as in the lower part of the image
  • Like 1
This.
I have drafted a design with outer dimension of 68mm - depending on the brand make model of the rim will determine the dimensions.
See below for VOLK - Style centre cap
CNC Machined Billet - Polished or Flat - black shade, color inserts, possibly Carbon outer - designs and styles are endless with cnc machining.
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
