Was talking about this with my wife tonight. My biggest impacting one hit wonder is....
Deelite's Groove is in the heart.
It's played everywhere even these days, 16 years after its release. Despite big names on the track including Bootsy Collins and QTip they couldn't back it up.
It had and still has massive impact all over the world. It's huge and will continue to be for a long time.
What's yours?
https://www.sau.com.au/forums/topic/463023-biggest-one-hit-wonder/
Massive Attack are far from one hit wonders...
This
Massive Attack have sold millions of albums. A couple of their albums have topped UK and other countries charts.
While the singles from Mezzanine including Teardrop are probably their most widely known now, Unfinished Sympathy routinely appears in "greatest songs" polls.
A-ha , Take on me , i don't remember them bringing out any other songs back in the day .
Yeah thats a good one.
Film clip was awesome, even if the acting was atrocious.
  • Like 1
Well I say nothing they did ever compared to Teardrop, the rest were poor attempts in my opinion, barely raised a ripple, so still one hit wonders in my books.
I'd also like to say Boomtown Rats - Tell me Why I don't like Mondays, but I'll probably get told they also had a string of hits [i can't remember any of them so they must have been good].
There are some great ones there, so awesome!
The dude from OMC died young from some genetic issue from memory. I have a feeling his brother did too. Might be the reason for the one hit. :dry2:
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
