Lifting base pressure 15oddpsi will see more flow for more topend
What C/R is it running
You talking about raising the fuel pressure? Its already at 58psi. Figure another 25psi when under full boost you are looking at 83psi rail pressure.
Not sure on cr
1000cc injectors is way to small for 500kw on e85.....
Or at least a Aussie 500kw that is.
This ^
I made 604hp with my -5s on my Tomei motor at 27psi (still 2.6) on E85 with 1,000cc injectors twin bosch pumps and a Walbro 460 lift pump (to surge tank) and they were almost maxed out
Most GTR-s that run -5s here in Oz make between 450-480kw max on corn syrup
I think dyno read out is a bit too optimistic IMO but we all know how to settle this don't we?
you will need a drag strip
and a go pro
and a pic of 400m..........wait..........I mean quarter mile timeslip
  • Like 3
Not sure on cr
No, I mean 58psi base is already 15odd psi higher then the base we usually see, mine is at 50psi which is already high then normal
You don't know what the compression ratio is ?
What is the smallest id of your exhaust system?
3" I believe.... And its Rickys car, just so there is no confusion.
I did not build the motor so I do not know the specifics.
most modern fuel systems run 58 or so psi. That is where we normally run things. Had this car at 43.5psi in order to help with pump gas drivability but we had to turn it up. The ID1000's are rated at about 1150cc/min at 58psi.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
