HI everyone I have a rb25det neo turbo conversion going into my r32 20de. Haven't started it yet. Will the neo injectors bolt straight in as both are top feed. Or are the o.rings different sizes.
And has anyone done this conversion with some feedback
Cheers
Edited by 32skizza
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/
just saying you're going to regret it and then go ask yourself why you wasted so much time and money on slapping a turbo to a RB20DE then paying $1k for a tune and find out it's slower than your neighbour's bottom of the range diesel golf.
  • Like 3
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/#findComment-7692471
Lol stop replying don't wanna hear it. Ain't paying any money all ready have parts apart from few fittings. Already have ecu and tuning myself. It's my daily. not a race car. That's in the shed.
cool man, do the conversion then.
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/#findComment-7692650
if your looking for a cheap rb20 injector, xr6 injectors will work with different o rings and spacers as the xr6 injectors are longer, or you could just cut the plastic section off the top of the injector and it will fit will no spacers as i've trial fitted one stock xr6 injector just to mock up.
note: factory xr6/xr6T injectors are a down grade and smaller than 270cc
http://www.ebay.com.au/itm/6x-New-Genuine-SIEMENS-875cc-80lb-Ford-Falcon-BA-BF-NA-Upgrade-Fuel-Injector-/151321721730?hash=item233b7a3b82
scotty might be able to get them in a better price
http://www.sau.com.au/forums/user/63525-scotty-nm35/
for a det+t id run a normal thickness metal headgasket so that the compression is not changed and still higher than a det
Edited by Dan_J
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/#findComment-7693128
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
