Im getting the drive shafts repaired and the Skyline run on a dyno this Thursday as I have got my supra FMIC from ebay. If the result is impressive, I'll post. If not I'll be hoping that no one has viewed this post.
The guy doing it is Marcus Blythe from Flow Tech EFI in Greensborough.
https://www.sau.com.au/forums/topic/46358-hr30-on-the-dyno-this-thursday/
  • Replies 69
Oh shit, I've just looked at the intercooler and it has had a 5 cent modification, (looks like somone ran 5 cents down the cooling fins) Wanker on ebay said 'great condition'. The seller is Tominien or something like that.
Besides that it doesn't fit properly, i'll need some pipe work. Still get it tuned anyway.
And the result is 207rwkw!!!
Apparently it is an after market turbo but was leaking pressure because it wasn't sealed properly when fitted and was leaking the hotter it got.
So the guy resealed it tuned it properly and it is producing 207rwkw running 18psi at 6200rpm.
Then the president called me up and asked me how to fix the whole Iraq situation and while on the phone I heard a womans cry for help and it was Lois Lane, she was stuck in a car while an earthquake was going on then time went backwards and superman came and rescued her....
Sorry, had to make up a story as it isn't ready yet. I am so full of shite :)
all righty then??
I'm guessing you'd be an annoying prick to work for... :) lol
I'd be interested to hear what it makes too, don't mind the ol' 30s :D I'm a bit behind the 8 ball, what's done to it? So far I know it has flash custom driveshafts and modded FMIC :D
and the moment you've all been waiting for. Here are some pics. It is really dirty so I'll clean it one day and put it up.
I wouldn't say I am annoying to work for..... more just a little misunderstood, I like to laugh like a mad scientist every now and again to keep the employees on their toes... :)
Got to wait until Monday, Those hot diggity darned drive shafts are a prick to get rebuilt and given how shagged they were, Marcus didn't want to flog them on the dyno until they were rebuilt, so I have to wait until Monday. I knew he didn't realise how much of a pain in the arse they are to get, but he called me and told me he'd have them Monday @noon the latest.
Good news is the intercooler is in and he has hotted up a shit load of R31's and VL's Turbo and Atmo.
Hey, a bit more positive feed back on the $150 mag wheels wouldn't go astray ;) I stuffed around for ages trying to get the size of the pic files small enough to get on this thread!!
Driving a VT wagon until then, biggest POC on the road.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
