You got a shitty tune in there thats for sure.
If you need a more detailed explanation on how to get it sorted pm me your number and I can walk you through it if you like.
do you have the hand controller?
Edited by mr skidz
  • Like 1
I have the hand controller but it's currently locked out. I should have my own copy of fc datalogit next week. I have notes of what settings were what before the tune so I should have a couple things to reference from.
Bit hard to see, but got quite a lot of knock and had to jump off it straight away. My wideband was showing 12.6@wot before I had to back off.
The issue is, why am I getting such high knock reading if there wasn't any when it was tuned the way it is now? Only thing that I have changed since having the car home is new coil packs (splitfires).
Reasons can be:
*too lean as i told you before
*maybe timing is too high
*bonnet was up with huge fan in front when tuned vs reality which is bonnet down and engine and cylinder head heat soaked to 60deg+
*or just shit tune overall
Im guessing all of the above.
I wouldn't be driving it and loading it up in that state you might be up for an engine pretty quickly
Edited by mr skidz
I know when i had my new splitfires installed
The tuner had to recheck the base timing as sometimes it may throw it out and with a power fc or nistune base timing effects the whole range
Dont need a full retune just recheck and adjust the base timing back to std
I don't recommend playing with the cas if the tune was done with the wrong Base timing.
Touch cas, redo through whole timing map
  • 5 months later...
Changed to an external gate off the factory manifold and was able to safely add in 8 degrees of timing before I heard light detonation in the ears. So backed out timing a bit and let it be. Pretty happy with the result really. Yet to run it on the dyno, but I prefer trap speed at the track.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
