hey all,
Building a 25/30 for my track car.
This is what i have at the mo
Rb25 head
Rb30 block
HTA3076R turbo
Trail waste gate
Dump
Screamer
6 Boost Mani
Plazaman Plenum
G4+ link computer
Aeroflow Fuel Rail
1200cc Injectors
BOV
Spitfire coil packs
Fuel set up for E85
So im looking to hoard some more parts
What do you suggest for the, crank, forged rods, forged pistons, oil pump, head studs and sump?
Am i missing anything?
Looking at around 400kws
Edited by Adz2332
https://www.sau.com.au/forums/topic/464313-2530/
Oil mods. Oil mods. Oil mods..
Baffled/larger sump with a couple of -10an fitting welded onto the sump running to the catch can to help relieve bottom end pressure so the oil can drain back quicker, and so the top end doesnt pump the catch can full.
Drill out the block and head oil drain out. I drilled mine to 10mm to help get the oil down quicker.
Head to sump drain/vent depending if you think its worth it. I dont but some people think its a good idea and acts as a drain. Also could work hand in hand with my first point.
Decent catch can vented or how ever you want to run it.
Will be using my current N1 oil and water pump. WIll be throwing stonger gears into the oil pump before swapping it across.
Restrictors in the block. Work out what you think will be the best size depending on vct, lifters and how you will be using the car.
Im using standard crank, balanced polished and tested.
Ill be ordering forged rods, ARP head studs, main studs
Have cp 86.5mm flat top pistons.
Not sure on my bearings or head gasket yet.
My head will get a full recon. New lifters, valve steam seals, swap my cams across, mods for the vct. GTR cam covers etc. If i didnt really care and was a budjet build id just slam the standard head on and be done with it. Im building this engine up over many years so im not in a rush as im still driving/upgrading the car over the years too.
Thats all i can think of for now. Ill be watching your progress and seeing how its all unfoulding.
Apparently once you let the Nissan out, they are never the same. But ill roll the dice.
  • Like 1
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7715012
Standard NA bottom end, standard head with wobble sticks if you can afford them.
Enlarged sump with trapdoors/baffles if tracking it. Put 2x -10 fittings on sump regardless.
Take baffles out of cam covers, fill with fuel cell foam and put baffles back on.
Appropriate oil restrictors in block depending on what head you are using.
Then put together and thrash the absolute f**k out of it like I do with mine. HTA3076 should be a killer turbo. If I was you i would go 1.06 rear and really turn up the boost and see how you go. I imagine you should make around 400ish kw depending on a few things.
  • Like 1
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7715024
Yeah better oil pump, but ARP studs and stuff all good. Doing the same, but slowly. Have RB30 motor, RB25 head with VCT, oil pump, water pump, and gasket set. Next buy is rods I reckon. So also interested in what you are doing, what you get, and how its going.
  • Like 1
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7715035
Ill be using H beam rods and CP flat top forgies for mine.
SUmp wize im going to get my standard 30 modded with the weld on fittings etc. Not sure if there is any off the shlf items, but i cant say iv looked as im not at that stage yet.
  • Like 1
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7715072
excellent. might have to contact a couple shops here in SA as im not mechanically minded so would either need someone to do the work or get an off the shelf item
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7715095
RBs have their peculiarities so ask around for a shop familiar with (and expert at) RB engines.
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7715171
Limit revs= I found with mine that it was quickest when I shifted at 6250 if I recall right, it kept it in the sweet spot on the torque curve, your build will see a different torque curve so limits will be different, also from my understanding the 30 will be more reliable keeping the rpm down a bit, harmonics or some shit.
Noise limit= some joints don't like screamers due to exceeding their noise restriction limit, plus what is the benefit of a screamer over a plumbed in gate?
https://www.sau.com.au/forums/topic/464313-2530/#findComment-7718239
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
