Hey guys
I want to replace my engine oil in my R34 (RB25DET Neo). I've done some research on the best oils. Everyone has their own opinion on oils but the majority seems to be leaning towards the Motul Turbolight 4100 engine oil. So I went to a couple of stores to check if any has them in stock but na-da, nothing. Autobarn has 2 Motul oils which are 6100 synergie and 8100 x-cess. I asked one of the clerks at the store and he said that I should try Auto Pro, so I rang two Auto Pro stores and they both told me that Motul has stopped producing turbolights and that Motul has replaced it with Motul H-Tech 100 Plus. Is this true?
Has anyone tried Motul H-Tech 100+? Is it really the replacement of turbolight and is it the same or better?
Also, a store here in Perth has Motul 300V Chrono in stock which apparently is some high quality shit for if you're going to the races or something but it's $110 for 4L! And I only use my R34 as a streetcar and daily drives. I'm not planning on racing with it or going sideways. Will the 300V be worth it as a streetcar?
Also, now that winter is starting should I look at buying a lower viscosity oil?
What do you guys reckon?
Edited by Joni Boi
300v is awesome, made my car noticeably faster. No joke. Not wallet friendly though.
I used to use 4100 religiously and it's a good oil but yes, you can get equal/better oils for same price and it pissed me off that it was so hard to find, so ended up switching oils to something most stores stock.
Oh ok, I thought turbolight was good for your turbo or something lolz, I don't know much about engine oils. But I'll try get something full synthetic 10w-40 like junkie said
Nulon Hi-Tech 10W-40 or Penrite HPR10 will be fine. Grab a few when they are on special at Supercheap. I have 4x bottles of HPR10 in the carhole
Cheers mate :) I'll do that tomorrow.
Anyone els want to voice their suggestions, I'm still open for anything els to try
for me, Castrol edge seemed to hold temp and oil pressure better, I noticed oil temp went up when I switched to the penrite 10-tenths. Will likely go back to the Castrol at next oil change, but would use penrite again if needed, and it is widely available.
I bought new oil, filter and sump + washer bolt (from nissan dealership). Came home, jacked the car up, went to go unbolt the sump and f**k me, the bloody thing is stripped...
Now I've got a problem that I can't be bothered posting a new thread about so I'm gonna post here. It keeps turning anti-clock wise but it won't come out, not even a little bit. $@!$$@!!! Previous owner or mechanic must have over tightened it when they changed the oil. I really don't want to buy a new drain pan. This is so stupid! :rant: I tried getting a screw driver under the sump to lever it into a thread but cant get a gap between the sump and pan. Also tried loosening and at the same time pulling it with pliers but no dice.
GUYS, don't overtighten stuff!!
Edited by Joni Boi
I would assume the same as the coolant drain bolt: 34-44 Nm?
I just tighten it and when it starts getting tight, just nip it a little. Won't fall out lol. You can put thread sealant on the sump so it never leaks.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
