Hi all :)
Long story short I got pulled over and police escorted to an RTA Inspection / defect station as well as having my car tested for noise by the EPA on Friday night. While this may sound incredibly scary to some, I made it through the RTA inspection / defect station without any issues and they were actually quite nice and in the words of both the 4 highway patrol officers who were looking all over the car as well as the 2 RTA inspectors they said "Mate this is a mechanically great car, there's nothing wrong with it at all and it shows that you know what you're doing and that you care" which I will take as a compliment!
Tf4J2tL.jpg?1
After that lovely ordeal I was directed to take my car to the EPA man who did the exhaust noise test, he was actually a really nice guy and explained the law/rules/bullshit that governs the legal limit of noise a car can make. After revving my car with the microphone he explained that the legal limit was 90db, and that throughout the whole rev range my car was under the limit (hooray!) until he backed off the throttle, and each time he did this it would spike to 2db. He also took the time to run me through the rev range and let me watch the computer/device which showed a db reading and showed that every time he did it it would spike.. After a good 20 minute chat about exhausts and mufflers he decided not to fine me for exceeding the limit, however I will need to go to the EPA and have it tested again after I "fix the problem".
My main question is how can I permanently stop the noise from spiking so much when the throttle is closed. I'm well aware I can bolt on a stock system and go to the EPA and pass so please don't suggest that, I'm not interested in a band aid, I want to be confident that if ever get pulled over again it will pass AND I honestly hate loud cars too.. Does anyone know of a certain muffler style which will help this, or would mild steel sections perhaps be the answer? The EPA guy also mentioned that they do not care how thick the exhaust's diameter is, nor do they care about the material it's made of, they just want you to adhere to the noise limit.
I am currently running a Kakimoto 3" stainless steel system from the cat back which has 2 mufflers in it and is quite quiet until you jump off the throttle.. does anyone have any thoughts about how I can modify this system to suit my needs?
Appreciate it!
https://www.sau.com.au/forums/topic/464694-dropping-2db/
Kakimoto are famously a bit raucous and raspy on over-run. Perhaps you had best get some photos of the mid and rear muffler into this thread. Blu-tac your phone to a stick, put it in video mode and pass it under the car a couple of times. if the mid muffler comes up as an obvious fix (ie it's really small) then we could point you towards getting a bigger replacement. But without actually seeing what's there, it's going to be a bit of a fool's errand trying to come up with suggestions*.
* I can come up with several, including putting in a 2" section, putting in an orifice plate into one of your flanges, stuffing steel wool up its arse, etc etc. But of course, these are the ones that we know will work regardless of what else is there, but that you do not want to do.
  • Like 1
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724141
"over-run" that's the term I was looking for, cheers!
When I'm next with my car ill take some pics of the mufflers that are there, I know the question kinda left you all in the dark but appreciate the help so far :)
I had a 3" mild steel system on my R32 which was great which had 2 straight through mufflers which came out to a 3" tip but im almost sure the kakimoto would be the same, the only difference being that this system is stainless.. If i was to get a mild steel system do you think the over-run sound levels would drop at all? I know stainless is certainly more raspy but how does that translate to db.
Sorry for all the questions lol :)
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724145
It you're running an aftermarket ecu, just enable the fuel cut on decel earlier.. There's a lag time which allows fuel to be injected after TPS of 0% the lower you set it, the less fuel is injected on decel reducing the over run crackle/farts/pops another way is to introduce another resonator, muffler, etc.
  • Like 2
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724233
Go to one of the flanges of the exhaust, undo it a little and slip in a gasket made of tin with a 1.5"-2" inch hole in it.......remove after test..... :D
Or easier still, a removable external exhaust silencer: http://www.ebay.com.au/bhp/exhaust-silencer . Good in theory at least but not much $ to test it out.
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724491
That's a great idea, unfortunately I'm only running a Apexi SAFC on a stock computer..
I know it's a dinosaur!! but for a stock car it's fine for now :)
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724543
It's a real shame exhaust valves are illegal really, I watched a guy with a varex get his ass handed to him by the EPA right next to me...
Thanks for the tips though, coke can gasket oh boyyy love it!
Cheers Tom
Umm wat, I thought HSVs and most late model performance euros and exotics ran bi-modal/valved systems from factory, fully street legal? Or is just that they never get selected for 'random testing'?
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724642
Go to one of the flanges of the exhaust, undo it a little and slip in a gasket made of tin with a 1.5"-2" inch hole in it.......remove after test.....:D
^^^ this lol
Done that before to pass a full inspection in SA, worked like a charm. Car drove like shit tho. Stopped down the road after the inspection and dropped the 2 bolts from the flange and left the gasket on the side of the road. Happy days
https://www.sau.com.au/forums/topic/464694-dropping-2db/#findComment-7724668
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
