Anybody Have One Lying Around ?
After a factory rb26 fuel rail spacer/washer after i dropped my one through my FAT fingers[emoji21]!
Soon as i kick my car over the bastard will drop I'm sure of it.
anyone who's changed there fuel rail might have one from there standard rail they took off.
After one today if possible[emoji85]
in sydney area afc83031c193e894e916cb03f3c4edaf.jpg8f72062478d89cb7300ed8384be02d1e.jpg
That is the plan, I do have a couple of days up my sleeve to try and find it though I just thought Since everyone likes to change the rail there would be many of them around but clearly not
Just use a couple of washers on top of each other to the same thickness.
I did this a while back when I was in the same predicament. Worked well and had no issues other than the feeling of doing something dodgy.
  • Like 1
Ive got a guy who makes me shims for bike suspension/ chassis stuff i do from time time so matching it up isn't an issue.
its me wanting every nut and bolts OE unless its absolutely impossible, EVEN IF YOU CANT SEE IT im that anal.
Keeping my 32 OE is always my priority even over performance.
I'd rather have a mint classic than a record holding lightning quick pig. ✌
  • Like 3
you'd hate my car :)
 Share
    • Best option. A cheaper option is a Xtreme Twin Plate, Organic Sprung Centre
    • Transmission synchros feel pretty bad at this point in my car and sometimes the clutch feels like it has an inconsistent engagement point in the pedal travel. I figure if I'm going to swap in a new transmission I may as well also put in a new clutch. Obvious candidates are ATS's pull-type twin plate carbon clutch, Nismo Super Coppermix Twin, or some organic clutch option I haven't figured out yet. I have searched this stuff to death at this point and still don't feel all that confident in making a decision. Target power is not much. ~330 kW at the wheels max. I ballpark the torque spec at 600 N-m. The stock clutch feels a little light so a little heavier is ok but I would say no more than 15-20% additional pedal effort. For some reason most clutch manufacturers want to keep this stuff a secret but the Coppermix Twin is 950 kg clamp load so I figure it can't be too much heavier than stock. The hang-up I have is some people mentioning that the clutch is very grabby which sounds like a pain. The stock clutch is almost too easy to modulate so I don't mind if it requires more precision than that but I don't want to deal with something that feels like I'm getting rear-ended at every traffic light. Also I see some mention of the release bearing carrier sizing requiring some work which sounds like something that might complicate installation? It would be good to know exactly what is needed here for a 1995 R33 GTR. The ATS clutch is supposedly the best but I've seen some complaints that they wear out easily and also slip when cold. I don't know how much of that is true but the cost is also huge compared to even the Nismo Coppermix twin plate. It's also unsprung which normally I would reject immediately but supposedly carbon clutches don't need it. The higher clamp load at 1300 kg is also a little concerning but to me more clamp load seems like it inevitably means more pedal effort and also more strain on the engine crank thrust bearings.  This is a street car and despite being a weekend car I seem to spend a lot of time crawling in severe traffic congestion with it anyways so I will gladly pay to have something that is easy to drive on and will hold the power with no unexpected headaches. I really don't want to do a clutch twice.
    • Grease the poly bushes as your first order of business. Moly grease. Spanner check everything else. Inspect LCA inner bushes.
