So I just saw that Obrien auto glass is running a comp to win hot laps on the same day as the SAU track day.  So looks like between rounds, we'll get to watch V8 supercars again :D
http://www.obrienautoglass.com.au/hotlap/
9 hours ago, Bazil_1 said:
Are there still spots remaining?
Hoping to have the car running again by Sunday, if so I'll book asap!
Yes we still have some spots, but they are filling up fast.
21 minutes ago, kila32 said:
I'm in, just paying online now.
Ok payment sent, I'm in. Last year was fun, hopefully it won't be raining.
Return of the rexy.
  • Like 1
14 hours ago, niZmO_Man said:
Wasn't it more fun in the rain though? AWD + PS3 in the wet = chop the Skylines on semi's :P
hahaha that was a lot of fun, won't be upset if it does rain. I would like to see what times I can get on a dry track.
That spin was great, I think a lot of us had a few hiccups that day.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
