4 minutes ago, PranK said:
IOS or Android? Do you have the latest version?
Yes the app was updated yesterday. iPhone 6s
i can see the login screen on the app but unable to click on it
I just tested ok on an iPad mini (the only IOS device I have.)
Is the login link you're clicking in the menu?
yes the drop down menu says:
Create An Account
Log In
Actions
Mark as Read
Settings
I am clicking Log in but nothing is happening when I click it
2 minutes ago, pol1on1 said:
Hi any ideas on how i could fix my issues that im experiencing.? @PranK
Woops, sorry I missed your post.
Can you see anything in here http://www.sau.com.au/forums/discover/content-posted/ ?
7 hours ago, pol1on1 said:
Yes i can see the url posted and yes once i logged in via the link you provided yes i can see my activities that i posted in content i posted in. But not in Android app.
Hmmm. Is it the latest version?
2 minutes ago, Missileman said:
Have not been getting any email notifications since the update, am I doing it wrong?
Can you check your address is correct? If emails bounce we disable notifications.
I occasionally get random notifications from the mobile app for threads that I've never participated in, in sections of the forum I rarely go into. Any idea how I stop them. The notification just has a speech bubble with 3 dots in it.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
