copy paste link in post (or paste into "Insert image from URL): IMG_1207_zpsqjf4bp0i.jpg
.....aaaaand its working today :|
well thats good. Thanks Prank [emoji14]
yesterday was saying "there was an error embedding: error" and post would show a URL only. Happened to me the day before as well.
If only we could see the pics on the mobile app....
  • Like 3
Can those of you with app/image issues please test and let me know if it's still happening? Also let me know your OS.
It all seems fine for me now on my Android.
What about the message at the top of the pages that say emails are being returned? :/
Still happening for me. E.g. Madbung's post on Cars That Make You Hhnnnnnngg (the most recent post)
Android.
  • 2 months later...
Im on the latest sau Android app and i get broken cookie image 98% of "the n1" thread. [emoji52]
Only got to see at wodgona mines gtr
Brenddons car that went to heaven
And my penis cartoon
The rest broken cookies
Same.
Also I have noticed that notifications are not coming through consistently. Received some for the lulz thread but not this one. Possibly related - the Notifications view in the app isn't showing any threads since June 1st.
6 minutes ago, Robzilla32 said:
Same.
Ive noticed with the notifications, if you log out and then back in on the app it's like it resets itself and you start getting them again.
Yep have already done that and it quite often has resolved this in the past but not this time.
E.g. a notification for the post by@pol1on1 that I quoted came through when I was reading your post but the notifications view in the app still hasn't updated.
I don't get email notifactions or notifacations on the app (iOS) anymore. And I still have the popup saying "Emails that we send to you are being returned to us. If our emails continue to bounce, we will stop sending emails to you and require you to update your email address."
On 2017-6-16 at 2:16 PM, pol1on1 said:
Still no fix ????
photos still not showing.
This has been logged with Tapatalk (who build our apps). I'll update you when I get anything.
  • 2 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
