Turbo setup for sale
Garrett T04z turbo
Steam pipe manifold - T4 Split Pulse Manifold so a very good design
Intake pipe
Dump pipe
Screamer
Hot side cooler piping
Will also provide the bigger housing which came with the car.
Absolutely nothing wrong with setup. Selling to go bigger.
The setup made 370kw with stock head and the small housing. should crack 400kw with cams and head work.
Will also have the following for sale if you want complete setup (not included in $2600):
3" exhaust - very quite and awesome for a street GTR - xforce (i think)
Apexi power fc D jetro with hand controller
1000cc injectors
Located Smithfield Sydney
Edited by usmair
