Alright so about 2 days ago ive changed the coolant and actually put coolant into the car as before it just had water running through it, my car has been overheating roughly about 15-20 mins after driving depending on how i drive it if i thrash it it starts climbing but if i drive normally it keeps cool then slowly starts to heat up. Ive started turning the heater on full blast as that sorta fixes the overheating problem while im driving but does this mean it could be the thermostat thats screwed or could it be something more like a blown gasket or something? ive noticed that some hoses on top of the engine have some crystalised brown stuff leaking from them, could thise be the old coolant thats clogged up and crustified there blocking the flow of oolant into the engine?
also another question are any other struts from other nissan skylines interchangeable with the struts i have now?
Please any help is appreciated and needed!!!
https://www.sau.com.au/forums/topic/465870-problems-with-my-r34/
Have i bled it? like Burped it?-.......No i forgot too, hopefully that fixes it.
Fluid level is good as the reservoir tank and radiator are always full and only require little bits of coolant to be added after running and turning off but i might need to burp it.
The bottom hose is hot
and the top hose is firm when its up to temp.
Ive been reading and im thinking it could actually be a blown head gasket.
One day i overheated and my reservoir tank was boiling/bubbling/popping it was going nuts could that be head gasket?
If you haven't been using "anti-freeze" your system could  be full of rust and cr*p.
First try bleeding all the air out (search if you're not sure how).
Get a radiator shop (or your friendly mechanic) to put a pressure tester on the radiator to spot leaks or may tell you if there is a major leak from the head gasket. Have a look through the filler at your radiator core. May need cleaning or replacing.
Get a new radiator cap, sometimes they get old and the spring wont function thus not letting water into the engine at operating temp.
Also do a proper bleed, top up the reservoir past the full line. Top up the coolant, turn the heater on full and whilst the car is running loosen the coolant bleed screw near the front of the plenum until coolant comes out.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
