  • Replies 165
Yep, same as Snowman and I think Geoff. (and others) It's so easy to do, just get it done and get out there.
Membership form found here:
http://www.ndsoc.com.au/site/files/membership.pdf
After that comes back get cams here:
http://www.cams.com.au/downloads/competito...2004/Level2.pdf
Suggest not posting cheque and form to NDSOC and waiting until they come back, cause that took 5 weeks for mine to happen. I'm sure if you make a few calls you can get it done quicker. Assuming your intending of doing PI event. CAMS application can be faxed to them and done on the same day if you ask nicely and have a credit card.
Ok guys - just some idea's for the best way to get CAMS for those that don't have it but are thinking of coming down. A couple of things to consider is that it will be late August and most membership expire on Dec 31st.
A lot of us a members of the NDSOC. The one thing NDSOC will get you is access to the MSCA sprint days. There are 4 of them left this year - the hill climb at Morwell as mentioned by Geoff, Phillip Island in September, and one in Nov and Dec - venues not confirmed but I have heard that they will be Calder and Sandown. Cost to join them is $65.
You can also join the Phillip Island racing club (PIARC) for $50 but this will only get you onto normal club track days (like maserati, ford, wrx, etc - but not the MSCA).
Also hopefully SAUVIC will be able to issue licences before then and we'll have the same rights and costs as a PIARC membership.
As for the CAMS L2S licence - if you aren't doing Morwell the easiest option is to get the licence on the day at Phillip Island. Just one less thing to have to wait for in the mail! If you are going to join PIARC you can do that on the day as well.
Side issue:
Bepo - spoke to Nige on Saturday as well and he said he's looking at joining us for this weekend as well in his Supra. It will be his first track day in it as well so you could both have some comparisions to talk about.
Sorry mate - what I mean by that is that we will have our CAMS affiliation approved. As I previously mentioned we have our review date at CAMS on July 28th. But I have no idea what happens from there. Starting a CAMS based club isn't something I've done before! LOL
So I'm not sure how long or what else is involved in us getting our approval - but once we are a recognised CAMS affiliated club we can take members and those members can then use the issued club membership number to get a licence.
I hope it will be done well before August 21st but I can't be 100% sure at this stage.
Well thats that then, im leaving my car at home and nominating myself to ride shotgun in the Supra all day.... :(
On a serious note, im ahppy to look into accom since Snowman looked after the arrangements last time...share the burden :)
Hey Roy - I'm more than happy right now to let someone else take the burden of looking after accomidation this time. I have enough things on my plate right at the moment with SAUVIC to be more than happy to handball this task.
yeah its a national cicuit road racing license. Its the license i use to race my formula 3
In that case there is no way you can race with us :)
What club are you with and can they race in PIARC events?
Time to start thinking about registering guys.
Roy - I'll definatly be going.
Check out this thread http://www.skylinesaustralia.com/forums/sh...6231#post966231 Doing an oil cooler group buy. Might interest a few of you before hitting the track.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
