talked to a bloke out at spoilerfactoy today ,
and he was telling me that any skyline that was produced before 1995 was alright to have a carbon fiber bonnet the only issue was the holes ponting to the windscreen ,if they are closed it is legal
is this bullshit or what ?
cause i would love to get a carb bonnet, but not if the cops are gonna pull me over and see all the other shit under the hood
#######sorry about the double post, accidently pressed the post button then tried to change and ended up with 2 post.
https://www.sau.com.au/forums/topic/46645-carbo-bonnet-legal/
reason to put carbon fibre bonnet beside reduced weight is to put to asssist cooling with the vents. something that factory bonnet is lacking. no point getting a carbon fibre bonnet if u have to seal the holes again. with such lightweight bonnet u need to make sure its secured properly and wont pop up on the freeway because it's "floating" against the wind pressure inside ur engine bay. having vent will reduce that lift effect. u can have have secondary bonnet restraint like in race cars, but u can get hassled having it on your road car as they can argue its a sharp pointing object that may cause injury if say... u hit a pedestrian (touch wood) and he/she slides over the bonnet and got cuts from ur vents or bonnet pins. laying low is the best defense. i'd rather have a wolf in sheep's clothing but its up to you mate. everyone is different.
I posted this in your out thread.
Please try and not doubble post topics.
In my opinion, According to the Eastern States Laws.
This is Pure and Utter Bullshit.
However, In your state Carbon Fibre bonnets, Maybe legal.
However the Bottom line is..
All bonnets must meet ADR standards, This means All bonnets must Crumple on Impact.
A carbon Fibre bonnet does not, It splits and Shatters.
Therefore Rending the Bonnet Not Legal.
The Smarter thing to do will be to contact the correct authorities, to check if mine or 'This Spolier Guy's" comments are correct.
Thanks,
Essential.
I have a question though, bonnet pins may harm a pedestrian... then is it legal to have those...i dunno...scoop like things you see on old fords and holdens...dont know the technical term, but they stick up right out of the middle of the bonnet... if small pins are illegal then how do they justify those things? (hope someone knows what im talking about :P)
It sucks, these car manufacturers can pump out pieces of ****ing shit because they suck off the government ministers, while we make SAFER mods and get raped for it????? Anyway, pssst, go get yourself some 'carbon fibre' contact, get a AIIIIIGHT shop to put it on for you, looks like carbon fibre but the weight of a normal bonnet, and VERY VERY CHEAP if you just want the look and no hassle from piggas (piggas are niggas who never could handle da hood)
I have a question though, bonnet pins may harm a pedestrian... then is it legal to have those...i dunno...scoop like things you see on old fords and holdens...dont know the technical term, but they stick up right out of the middle of the bonnet... if small pins are illegal then how do they justify those things? (hope someone knows what im talking about :))
its to do with the age of the vehicle.
I had an old 79 ZJ with a big scoop... but it cant be touched as it relates to a different set of ADR's :)
same as older cars dont need to run Cat converters...
older cars are allowed a higher DB limit on thier exhaust.
All sorts of things like that. You cant expect a 30 year old car to match currecnt ADR's
As for bonnet, it wont be legal in any state, as ADR's... are Aust wide.
Before they started having to crash test vehicles, you could do almost anything you liked, within reason.....
These days to comply with ADRs the manufacturer needs to do front impact testing to prove that the design of the bonnet and hinges will not cause the bonnet to come through the windscreen and cut your head off.
If you change the design, or fit non factory parts to your bonnet, catch, or hinges, the modifications would almost certainly be seen as illegal.
Yeah, there is a scoop.
Thats what has me totaly dumbfounded.
"apparently" its allowed to be a hold of a certain size... if you drill down into the law a bit more. Not 100% sure how Subie still got away with it though as the STi scoop is quite sizeable
I tried to get an answer to this very question from the RTA (in NSW) and was referred on to some engineers, who all disagreed with each other :)
The answer seems to be that nobody has a clue.
A few answers I got:
Hi,
This depends on the year and model of the vehicle as to whether it has been
subjected to ADR69 being full frontal impact protection and in particular if
an airbag is fitted.  Without testing (that can be very costly), one can not
continue to claim compliance with this rule once the material of the vehicle
strcuture has changed.
Regards,
Morry.
And (read from bottom)...
The material in itself is structurally sound but the application of it has
to be structurally sound.
----- Original Message -----
To: "Adcot Engineering Services"
Sent: Tuesday, May 25, 2004 7:16 PM
Subject: Re: [unclassified] Re: Carbon Fibre Panelling
Hi,
Thank you kindly for the prompt response.
The material is structurally sound, however it has been suggested to me that
because carbon fibre has a tendency to shatter rather than bend, that this
could
be a problem in respect to the ADRs?
Thanks again for you time.
Lucien.
Lucien Wells, on 25/05/2004
On Mon, 24 May 2004 06:53:18 +1000, Adcot Engineering Services wrote:
> The choice of panel material is not restricted as long as it is
> structurally sound
LW.
