On 9/5/2016 at 7:40 AM, Anfanee said:
I just got this (literally 2 weeks ago) and it is fantastic for gaming.
https://www.pccasegear.com/products/31877/acer-xb270h-g-27in-g-sync-144hz-gaming-monitor
Acer XB280HK 28in 4K G-Sync
I recon its worth the extra $85, 1 extra inch but it takes it to 4k.
as i can only run 1 screen  ( i will run a secondary screen to watch movies on while playing stuff) but i dont have room for the 3 screen i wanted for gaming. im looking into the possibility of running 1 very large screen. like a 32-34inch, more money yes, but might be worth it for a single monitor setup.
Edited by GH05T
28" is 60hz @ 4k
27" is 144hz @ 1080
Personally i would go the 27" 144hz @ 1080. 144hz feels A LOT nicer to use even in windows. There is also less strain on the gaming system having to put out 1080 over 4k. That 1070 will struggle a bit on top end games at 4k....
I won't go back to sub 144hz again.
It'll do 4K gaming for sure.
But if you want a solid 60fps at all times, you won't be able to run them on Ultra detail.
A good middle ground may be a 1440p monitor at 125hz+ which your 1070 should be able to do.
Otherwise, Anfanee's suggestion is best bang for buck IMO.
Can't wait to see pics of this rig when it's built.
Its not a flashy rig, its got hidden led ring fans which you can just see through the case mesh and glowing ram and a few logos. Thats about it. Thats how i like it, im not a kid anymore :P i almost wanted a solid cube for a case.
Its so quiet though! The thermal take fans with the stepdown cables are so silent. But they work very well. The watercooler again is silent, i keep checking the temps to make sure their doing their job properly.
the corsair link is a good program too, very good to keep an eye on the temps and all the stats, i like stats :)
Was playing a bit of doom last night on ultra everything and it loved it. Much more enjoyable with good smoooooooth gameplay.
Played some no mans sky. That seems to need some optimizing. Unsure if its the game design being procedural generated or if it just needs tweaking but the terrain building ahead when flying in atmosphere is glitchy as f**k.
keen to fire up project cars tonight but even more keen to get my hands on an oculus and play Project C in VR.....
Love the keyboard. i have spent some time setting up the colourscheme for different games (and here me saying im not a kid haha)
my fav colour shceme out of game is white/ pale blue keys which hit red and fade back out, tracing your type.
but games are surprisingly better when your keys are marked for you and the rest blacked out. especially when playing games like Mechwarrior online where you have a decent amount of shit active on the keyboard.
Edited by GH05T
No mans sky is poorly coded. Your PC should feel lovely man, and with a good 144hz G sync monitor for gaming it will be so smooth.
Realistically you should get 4-5 years out of the processor and stuff. GPU maybe 2 years, it depends on what the gaming industry does. I'm expecting to upgrade my GPU around late next year.
By then a 12xx series will be out. 1180ti or 1260/70/80 will be out. Just replace the card. SLI still isn't worth the dosh for the upgrade. Though G-Sync does fix a lot of the issues SLI had it still is far from perfect.
  • Like 1
My latest purchase:
https://www.pccasegear.com/products/34610/corsair-h5-sf-low-profile-liquid-cpu-cooler
Building a miniITX gaming rig has it's limitations. One of those is cooling/space, apparently this thing hauls ass so hopefully i can push my PC even more.
  • Like 1
    • Just a thought, how come you didn't use a 4D table? So you essentially run 2x fuel and 2x ignition tables, and the table/map switch is handled when there's enough WMI pressure detected. This is mine, but using the flex sensor as the 4th dimension, note the slider at the bottom. Between 0 to 70%, the timing is blended/interpolated , once it goes past 70% ethanol full send
    • Hi guys, after dreaming of owning a JDM legend for 20 years, I got the chance to buy a 1995 R33 GTR.  I live in a small country called the Solomon Islands which is in the pacific. There is no performance car scene here, however 90% of vehicles here are 2nd hand Japanese imports so there is a handful of JDM sports cars here, tucked away.  3 Evo VI’s, 1 180sx turbo, 2 GTO’s, 1 R32 GTR and 2 R33 GTR’s.    Only 1 Evo and a 33 (mine) are active. I’m hoping to set up a club to get these cars back in the road.    I’d known of my GTR for 9 years and always dreamed of owning it. At the start of this year I found it sitting outside a workshop waiting for a respray. It was in pretty bad shape, although running and driving perfectly apart from a big exhaust leak and worn out bushings. My brother in law who is a huge GTR guy came over for a holiday and I took him to see it, he got into my ear and I bought the car 2 weeks later as is.   I’ve had a pretty bad problem with alcohol and weed since 2020 and I really wanted to quit. So I used this as my motivation. I quit everything cold turkey and have been investing all my spare time into restoring this car. It’s honestly been the best experience and has been such a positive impact on my life.  There is no market for these cars here, no parts and no mechanics that can work on them, so if you wanted to sell one it would be pretty impossible unless you found the right buyer. After a bit of negotiating with the previous owner (a good friend) I got the car for $15,000 AUD ($85,000 SBD) which is insane.  I’ve almost finished doing a refresh on the engine, new turbos, spark plugs and split fire coil packs. Also new gaskets and seals, This car had no leaks to begin with, but it’s due now being 30 years old. . Next I’ll be working on the suspension, all new bushings, ball joints, king pins and new coil overs.  Then it will be body work, it has really bad rust in the boot floor, I have purchased a rear beaver cut from my bro which will replace the rusted out one. The car is originally KL0, but was burnt orange when it landed here, then it was resprayed toxic green and then Bayside Blue. I’m probably going to get it redone in Bayside Blue.  I’m super grateful to be able to enjoy this car and couldn’t have done it without my bro Chris from OG-JDM. Looking forward to the future with this car and hoping to get it on the runway at the airport here 😂  cheers fellas
    • Also, it is just about triangularity. The less angle, the easier it physically is to do. Think of the amount of slip you're getting, as how hard you need to push an object. More slip, equals pushing way harder. Then the ramp is how steep the hill is. The Accel is less slip, which means it takes less pushing (less slip) to get it to be able to push apart. However, the steeper sides on the decell means it will take a lot more pushing (slip) to get it up the ramp.
    • It's the angle of the ramp from the vertical. You're measuring from the horizontal. To convert, take 90* minus your angle reference = Nismo Angle.
    • I agree, thus 45 degree is the *max* force one could apply to it. This is similar to what I've seen in uh... simulations... which allow you to play with diff ramp angles. Anything higher (or lower) than 45 degree would produce less force as 45 is the max... triangley.  I would state the 1 way is 90 degree, at least this is how my brain and other ways of explaining it refer to it. 90 degree also effectively acted completely open. I realise Nismo refer to it not as 90 (or 89) but "1". So I'm not understanding the angle on which these angles are based.
