R32 GTR misfire. O2 sensor readings.
Hey everyone, hoping I can get some insight into this..
I've chasing this misfire since months. Engine boggs heavily when cold until coolant temp reaches 60 degrees celcius. Clears up as soon as it hits that mark.
Engine misfires heavily under high load above 4000 rpm. 10 psi boost.
Engine is bone stock. Stock ECU.
Work done so far:
-New coilpacks and harness.
-Spark plugs BCP7ES gapped to 0.8mm
-Fuel pressure and injectors ok. New fuel filter. 12.4 volts at fuel pump.
-Smoke tested- found air leak and replaced all 7 intake gaskets and all hoses underneath. Smoke tested again - no air leaks now.
-Swapped CAS. no change
-Swapped MAFs. no change.
-swapped boost solenoid. no change
-swapped coolant temp sensor. no change.
-Base and ignition timing is on point.
Now i'm looking at o2 sensor readings. They don't seem normal to me but I would just like to confirm with anyone with more diagnostic experience than me. Here is the data from ECUTalk via consult.
Idle after hitting closed loop: 0:00 - 0:25
Shy revs: 0:25 - 0:30
Idle : 0:30 - 1:00
Hold rpm 1300: 1:00
Please. I will appreciate any input.
Thanks!
Edited by gotenek
https://www.sau.com.au/forums/topic/466476-r32-gtr-misfire-o2-sensor-readings/
Unplug them and see if the car drives better...
Have you tried swapping the ignition unit on the valley cover with a known working one?
I presume all parts were swapped with known working items?
Have you done a comp test?
I will try unplugging them thank you.
I converted to r34 gtr coilpacks so ignitor pack was deleted.
Yes eveything was from good running friend's car
Yes. Compresion test yielded even 160 psi on all cylinders while engine was hot.
Boroscope each cylinder. Valves and cylinders looked ok. Just a little bit of oil around the piston rings but thats understandable at 155,000 km.
Did this problem occur when you did the swap to 34 gtr coil packs?
Just stabbing in the dark but maybe that's your issue...
No unfortunately not.. its been there since a long time preventing me from driving the car
don't run them... you'll have shit fuel economy for now.. but at least the OEM ECU won't add in any funny fuel trims for both short and long term...
once you're ready, get an aftermarket ECU and feed a wideband o2 into it.
Sounds like you have electrical gremlins.
  • Like 1
Don't run what? Are you suggesting that my o2 sensors are okay?
unplug both o2, don't bother running them - downside is you'll have crappy fuel economy but that's Skyline life.
Oh i see i will try that as Hadouken suggested as well. I have new o2 sensors coming in 2 days. Just wanted some input on my current ones
New or used Engine coolant temp sensor swap in?
Check the wiring and the grounding and use a new one for $50 (kudos motorsport)
Used one from a friend's properly running car. I've checked wiring. Didnt see any voltage drop
  • Like 1
Put a scope on the negative of all the cylinders. #6 seems to be dropping below 5v. I'm not sure of what to derive from this. Checked resistance from signal wire to ecu for all cylinders and they are all at 0.182 ohms. Checked ground for Coilpacks. Resistance was nominal. Checked CAS signal wires (2) as well and they are a 0.145 which seems nominal.. I think
Swapped ECU from a friend's good running gtr. No change.. lol
Cylinder 6:
Rest of the cylinders:
If the engine is stock, and the coils are good, then open the plug gap out to 1mm. Also, you seem to have the wrong heat range plugs - the correct heat range is a 6.
BTW - I've lost count of the number of times I've had to say that the O2 sensors are ignored under anything but cruise conditions. So if you are on boost, the O2 sensors play absolutely no part in how the engine runs.
  • Like 1
I've gapped the spark plugs again to 1.1mm recently and no change.. And yes, they are bcpR7es NGK 6282 (typo haha).
The rpms start breaking up anything above 4000 rpm. The higher the load, the worse the misfire really.
Yes also that's cruise when the engine is up to temperature, and OPs problem is when the engine is cold.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
