Hi guys,
I'll start of by saying I'm no professional, really I'm doing this just to improve my solid works skills and hopefully end up with a replacement set of centre caps I can use. But I am planning on 3D printing a set of Ray's centre caps to fit lmgt 2's ( may fit 1's aswell?) as anyone with the caps know the plastic gets brittle and the mounting tabs snap off! I have seen sets go for over $600 in good condition... But really they are still 20 years old . All going well the final product will be made of abs plastic ( unless anyone has an opinion for otherwise?) yet to see wether there will be the ability to colour match to the originals otherwise more than likely black , cost I am unsure of yet.... I was going to see if there is any interest first so I could enquire for x amount of caps and see what happens but hoping around half the cost. All the dimensions and measurements are being taken from a genuine centre cap and I will get a mock cap made up first to ensure fit.
Is this something anyone/ones would be interested in? Nothing final just a gauge of interest at this stage.
Thanks!
https://www.sau.com.au/forums/topic/466765-lgmt2s-centre-cap-3d-printing/
As Ravi alluded to, I think that the hexagonal caps of the LMGT1, LMGT2, LMGT3 and Magnesium LMGT4 are the same; (but not the LMGT4 GT500).
Pete - aka PLYNX on SAU - has made them before.
They can be either be black or sliver-frost in colour.
just need to get the bottom section with the mounting tabs sorted (probably finish it tomorrow night or tuesday)
but overall it matches the centre cap i have here quite precisely so hopefully this week i can look into getting a prototype printed! if anyone here knows somebody or a company to go through to get them printed please let me know :)
thanks
  • Like 1
so.... if anyone is still interested the cap is done!.....well the file at least,  the mounting tabs were a pain but hopefully they work properly ( they are the same dimensions as originals so they should). Now to find someone to print it.
  • Like 3
i have spoken to a few company's, the one that seems to stand above the rest is Solid Concepts, they have a base here in WA and also Singapore. They have answered everything I have annoying asked them and understand the use/purpose to ensure that if this does go forward the product is more than up for the task and the finish is on par if not better than the originals. the 2 options i have been given are;
1. SLS nylon production- makes very low quantities viable  but isn't the best suited to the job, it's only available in white ( so will require painting) and the final product is from a 3D printer as such the finish straight from the machine may need sanding/ tidying up.
2. vacuum casting, firstly a set of master copies will be printed sanded/ cleaned/ finished before being used to make a silicone mould from which the final PP/ABS pieces will be made. the advantages being a completely finished cap ready to install with a professional finish quality and available in different colours ( probably matte black to resemble the orginals?). the downsides being the initial cost to produce the mould, to make less than 20 units the cost just is not worth it.... so on to that.
COST; really option 2 is the best option and the one i'm hoping to get enough support for to go with, at 20 units the price would be $80-90 a piece or $320-360 a set. I know this isn't cheap for a set of "fakes" but quality wise I am confident it would at least equal the originals ( likely better), I don't stand to make any money on the caps so it's not that there is a mark up on anything... its simply not cheap to create these low number runs. The mould can potentially be used for 20 sets (80 units) until they expect it to degrade so if there is enough interest (10+ sets) we could expect prices to drop $10-15 a piece but finding that many interested people may be difficult so if you do know somebody please let them know!
I am happy to do a production run with 5 people ( 20 units) but can't justify it for any less than that, so please let me know if you are interested still and i can get a definitive quote and get the ball rolling :)
thanks guy and if you have any questions feel free to ask
Nic
  • 4 weeks later...
As you can probably see the interest since pricing went up was well... less than great. But ohh well that happens. I did get a prototype printed though just to see how well I did recreate the part and I am very happy with how close to original it is :) if anyone does want the file please just pm me just keep me in mind if you do find a cheap way to get these made!
Thanks guys bcfc43d0d91ea8068d00845f8bf799a3.jpg2e9b2d4c86b0d2f113a39bf878b81545.jpga8a3628a7d6c603349007ca3522cb6dd.jpg7070c82cd6bc66f431df29c1ead1226b.jpg
  • Like 1
  • 2 months later...
  • 3 weeks later...
  • 1 month later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
