Buying a r33 gtst
Hi all,
So recently I drove my mates r33 (first rear wheel car I've ever driven) and that was enough to make me buy one.
I've got about a 25k budget and I want to space out the mods for the car so I don't kill myself.
Just want answer pls
  • What mods should I start with
  • What is the most psi I can run
  • any suggested mechanics (North Perth)
And anymore things for a newbie to know.
Thanks
https://www.sau.com.au/forums/topic/467576-buying-a-r33-gtst/
Read the R3B25 and RB30 turbo upgrade threads to see what people do and with what results and work out where you want to get to. Nothing more money wasting than doing things twice. With your budget i would take the time to look for a nicely modified car and save some time and money.
My opinion this is what i did with mine first and its what i recommend.
1. Complete service - new oils (engine, gearbox, diff) new filters (oil, air, fuel) new plugs, check belts. this way you know exactly what you have in your car and that it all has been done.
2. Brakes - upgrade to new pads and rotors, don't skimp here get yourself something decent
3. Tyres - check to see what is on the car currently, if it is a cheap unknown brand, get something that is known and quality.
4. Suspension - Coil overs or decent strut/shocks and springs, check all your bushes, upgrade sway bars.
now you have a good solid platform that will handle when needed and will stop, you can start looking at power.
5. Elec boost controller and new BOV, the stock turbo will handle up to 12psi, with a GFB boost controller you can adjust alot of perimeters like spool up rate, max boost, overboost cut etc. reason for new BOV is over time factory ones can bleed boost. Don't buy ebay stuff, do it once do it properly.
6. 3" turbo back mandrel bent exhaust.
now you have enough power to have fun with for a while till you get comfortable with the car. From here the mods are relative to the depths of your pockets
New turbo, coil packs, fuel system upfrade, ECU, Tune, E85 etc etc
From the questions you've asked I can already tell that you are pretty excited about making the purchase.
Basically have a good think about @Coullsy's post. Rather than focus on "the most psi" focus on the handling side of things such as brakes, tyres and suspension first.
There's really no point having huge power with no back up to stop you when it's needed most.
  • Like 1
its been mentioned before but i agree spend the money of making the car handle and stop before you look at power (dont cheap out on tires and wheels).  first power mods i made to my r33 were bigger injectors i put an r34 turbo in with 3in turbo back exhaust front mount z32air flow meter and new computer with nistune, with the r34 turbo im running 17psi.
im now looking at either building a forged rb26dett or doing an ls1 conversion because im used to the power now.
21 hours ago, conan7772 said:
Hi,
I'm thinking of selling my GTS-T 95
Already a rocketship.
Forged 25/30 337 rwkw
Got all the goodies.
I'm after $22000.
I will be putting up all the info soon,
I'm in Sydney though.
Create a for sale thread.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
