I drove a Porsche GT4
And I loved it.
large.20161103_172744.jpg.ffc99d1bbf266e
Holy smokes this car was amazing. I only had a small amount of time so I couldn't get it out of the city but it was so easy to drive it was still impressive at low speeds.
large.20161103_172816.jpg.9aeb6cba6c5f43
I don't think I got it into any gear above 3rd. This is partially because it sounded so amazing at 3 - 4k that cruising in 3rd was making me drool a little. The noise was just insane. Shifting down, despite it being a classic clutch activated shift, the car still revved up to match the gear. This took a little getting used to but after you did, it was quite welcome.
The interior was still very well equipped. I wasn't expecting much in the cabin, especially as though the doors have no inside handles, only straps (interesting given no other obvious interior weight loss or simplification.) The gauges were gorgeous and the rightmost "gauge" was a screen showing any of the computer data or the navigation.
large.20161103_172954.jpg.115de7bba509e2
The centre console was beautiful with a nice and responsive centre screen. Behind the gear knob were switches for ECS, Sport, Suspension settings and the exhaust butterfly (which I left open.) With the car in a 'normal' mode it is very comfortable and civilised. The seats are really low and quite difficult to get out of when you're as tall as I am. The alcantara steering wheel was just beautiful and contained no steering wheel mounted controls or buttons.
The shifter was very short which was nice, but it took me a long time to find reverse on the first few attempts. It is up to the left of first, but the channel to get it over there was very narrow and difficult to find. After a few attempts it became increasingly easy to find so maybe I just needed some practice.
But, as I am quite the brake-o-phile, I couldn't stop looking at them. Just look at them!!!
large.20161103_172716.jpg.9f84ad2d8f897e
See the rest of my pics here;
Here's a little driving video so you can hear it. If you just want the sound, watch from 1:00 onward.
What do you think? Does this float your boat?
  • Like 4
https://www.sau.com.au/forums/topic/467762-i-drove-a-porsche-gt4/
3 minutes ago, Aussie_Delivered_R32_GTR said:
Big ticket item now...........
New they are best part of $250,000,00.
Bob.
I just didn't get the price on it. It didn't strike me as a quarter-of-a-million-dollar car. $150k, yeah maybe, at a stretch, but no more than that.
Awesome. I have a soft spot for Porches especially the GT cars. It looks like it would have been super fun.
I get your brake enthusiasm, I have a real thing about car exhaust sounds, if I ever find myself with a spare few million I will be buying my garage based on the quality of the noise they make! (think LFA, Carrera GT, F458, E60 M5 so on, so on)
  • Like 1
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
