Wheel test fit
Hi All,
This is a bit of a long shot, but is there anyone on here who has either a pair/set of 10" wide 370z wheels that I could test fit? I just need to see if the spoke design will clear my brakes :)
I am willing to travel to you.
Thanks in advance
Steve
Edited by stag98
https://www.sau.com.au/forums/topic/467775-wheel-test-fit/
The only 370z wheels in 10.5 were nismo editions. All wheels offered on the 370z are staggered so youre not going to find a full set.
The spoke design has oooooodles of room for calipers. Unless your brakes are ridiculously big....
Edit: The wheel in the pic is 19x10 +30. I see you are fixing up the 10.5" bit.
  • Like 1
https://www.sau.com.au/forums/topic/467775-wheel-test-fit/#findComment-7792138
Yeah, I was thinking of the wrong specs but right wheel lol.
It is the 19x10 +30 version I am referring to. I know they're staggered but there's a mate of mine in SA who managed to find two pairs of this size so he now has a full set haha looks rad on his V36.
I have 6/4 pot AP racing brakes front and rear so I am assuming they'll clear given the spoke design but I just want to be completely certain; plus also see how the 19x10" +30 sizing looks.
Edited by stag98
https://www.sau.com.au/forums/topic/467775-wheel-test-fit/#findComment-7792140
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
