r33 RB25 whining
Hey guys,
Recently bought an r33, pretty standard beside a FMIC, exhaust and a pod filter., but it is making this weird whining/metal sort of noise whenever you accelerate. I cant get a good video of it but i found someone who managed to, but dont visit the forum anymore so i cant ask them what it was!
Video is here
First turbo/import ive ever owned and my knowledge is pretty small when it comes to cars, and for the life of me i cant figure out what the sound is. Car still drives fine, boosts fine (no gauge yet but should be arriving tomorrow) but the noise is really annoying and can be heard over the engine while driving.
Any ideas? cheers
Edited by Aestysu
https://www.sau.com.au/forums/topic/467958-r33-rb25-whining/
8 minutes ago, GTSBoy said:
Wait.  Is the noise independent of you twirling the steering wheel?
Nothing to do with the steering, its pretty much purely when i accelerate, and gets louder the more i give it.
Could be sitting in neutral hands out the window revving the car and it happens.
Probably timing belt since that gets whiney and noisy if: 1- the belt is a gates racing or similar. 2 - is too tight. 3 - probably both. Take off the top timing belt cover (after you carefully remove the CAS) and tell us what you see. I'm guessing a blue belt.
Pull ancillary belts one at a time. I'm putting money on power steering pump or alternator bearing.
Remember: Fan belt also drives water pump so don't run the car too long with this one off
Edited by 89CAL
Extra Info
thanks guys ill have a look hopefully tomorrow, ran into another issue gotta fix that first.
was driving, then all of a sudden lost all power, and car starts hopping. pretty much undriveable and just jumps every few seconds in bursts. it idles and revs alright in neutral, and also does reverse fine, but as soon as i use the accelerator it just hops around. thinking coils misfiring or TPS?
ok so didnt fix the new issue and seems to be worse now. Car turns over and starts, then pretty much instantly stalls, if i manage to start it, it doesnt want to rev past 2500, at first though it was coils/spark plugs but didnt fix it, then found the 2500 limit, so im thinking air sensor.
Cleaned out the maf, didnt do anything, let the car idle while i packed up and stalled, and still wouldnt go past 2500. going to try a new one and hopefully that fixes it otherwise im stumped.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
