  • Replies 41
I know it has most likely been covered elsewhere, but if your car is running illegal mods and you have an accident, is your insurance (compo or 3rd party) made void?
what if you list all your mods with the insurance company and they say its fine? because iv heard of people having insurance with Just Car insurance, and they listed all their mods and their fine, like BOV ect. I think just cars are the way to go if your young import driver.
Just Cars are probably the best for highly modified cars, the excesses are the only thing that makes claims expensive. However, they state on the policy that all modifications must be legal and road worthy. So an illegal mod or one that you dont have a permit for could give them grounds to refuse insurance, then you get into the whole legal battle of proving the illegal modification didn't cause the accident.
In QLD they can't be YELLOW, RED, BLUE or WHITE, or flash. can't see the bulbs and can't be DAZZLING to other motorists.
Main roads has made up a info sheet all about them, just go and ask them for one. Your rules down south are probably different.
BTW. Having the front number plate to the side is perfectly LEGAL aslong as it is viewable from 20m in front, and 45 degree angle.
haha good call kamikaze, thanks for url karina
anyway
boost controller is illegal as it adjust your factory engine emissions, more boost = more air = more oil / fuel / other volumetric crap changes from the factory "emissions"
in vic its only 1 air intake mod, pod or aftermarket front mount intercooler. unsure if factory still counts as one, i think it does.
shit like guages are allowed because according to ADR if mounted on the a pillar its in driver collision area. that is if you have a head on your likely to mash your head forward and bust your forhead open on the nice HKS boost guage you have etc.. if its monuted say in the console or near ash tray then i guess its fine
gear knob is ok but it has to have the 1-2-3-4-5-6 H pattern sticker on it to show "someone" else who may drive the car where 1st 2nd 3rd is etc...
pedals i guess would need to meet adr (australia design regulations) same with aerokits and big **** ass wings, they need to meet ADRS to be allowed and ticked off as Okay
turbo timer is illegal because your engine must NOT run once the key has been removed for safety resons. no other accessories other than radio and harard and horn i think should work when key has been removed for safety reasons. ie your windows must not go up and down when key is taken out, things like auto arming alarms that do turrbo timer function and wind up windows automatically is technicallly illegal as your engine and windows work when key has been removed
window tint is allowed only upto a certain darkness (in japan they had mirror tint!!!) -> cool effect hey : )
pod is illegal (well oiled one) because it affects your emissions with a normal air filter it just sucks in air, with an oiled pod (most are i think) it sucks in air + random oil from the pod. its not illegal for the noise, for the emissions. i think it comes into play becuase the bov can trumpet the air out into the atmosphere, whereas on an NA car it still goes out via the cat converter before it gets to atmosphere, could just be a technicality
there are other ifs and ums, things like the power to weight ratio (for p platers only)
which i believe is you must not drive any vehicle that exceeds X torque/killowats/power per 1000 kilos or whatever the scale is
so if you are driving a skyline 1995 GTST on your p plates and you get pulled over and they go power to weight violation you can ask for them to prove it
to prove it they must
a) weigh your car - easily done
B) measure engine output (not including drive train) - aka take the engine out on a hoist and dyno the engine, as if they are gonna do that
but then you can also argue that your rb series 2.5 litre twin cam turbocharged engine has 115,000 kms on it therefore its 35% worn and therefore its voluemertic capacity is only 70% of its factory output therefore its not 187kw at the flywheel its more like 160kw which would put you and your car under the power to weight rule. you could also say you have a special restrictive air filter that only allows the engine to suck 80% of its capacitiy there power is less - $x of 80% and so on
lots of ifs and ums, of course most of this is off the top of my head so i could be completely wrong in some areas, sorry if i am
oh and i just found (which is cooll and i didnt know)
15. EXTERNAL GAUGES
Gauges may be mounted externally forward of the windscreen in a position visible to the driver provided they meet the following requirements which are effectively the same as the bonnet scoop and protrusion requirements:
o The gauges and any attaching brackets or covers must be of a smooth construction with the edges suitably radiused so that they are not likely to increase the risk of injury to a person;
o The surface of any part of the gauge or cover visible to the driver must not be more reflective than the general bodywork of the vehicle;
o If the gauges have instrument lighting then the intensity of the light must not be greater than that of the interior instrument panel;
o The gauges or covers must not prevent the driver from having a clear uninterrupted view through the full width of the windscreen of all parts of the road surface 11 metres forward of the steering wheel viewed from any driving position permitted by the range of adjustment of the driver's seat.
o If the gauges or mounting brackets have sharp edges or are constructed in such a way that the likelihood of injury to any person is increased then they must be covered by a faring which presents a smooth surface when viewed from the front and side of the vehicle.
It is recommended that pressure gauges are of a type that are electrically controlled, however if pressure lines are required to operate the gauges then the lines must be suitable for the pressures and temperatures involved, braided type lines are preferred. The lines must be appropriately supported and routed so that they are not likely to fail or be damaged during normal use.
Probationary driver licence holders must not drive high powered vehicles. A high powered vehicle is any vehicle with a power to weight ratio over 125 kw per tonne, or with an engine capacity to weight ratio over 3.5 litres per tonne.
Capacity to weight ratio is the capacity in litres divided by the weight in tonnes. Power to weight ratio is the power in kw divided by the weight in tonnes. In doing calculations, weight is specified in tonnes (1000kg = 1 tonne); capacity is specified in litres (1000ml = 1 litre); power is specified in kilowatts (kw) and is as measured at the engine flywheel.
The weight of a vehicle is the unladen mass specified by the manufacturer for the stock-standard vehicle (without options). Since 1988, this weight is specified on vehicle data sheets, as published by the Commonwealth Department of Transport and Regional Services. Vehicle manufacturers provide the information used to prepare the data sheets.
The file attached below contains a guide to vehicles that are classed as high powered motor vehicles. The Guide only covers standard vehicles that have been made in Australia, or imported in bulk, since 1970. It does not include all high powered motor vehicles. If you are concerned that a model not included may be a high powered motor vehicle, then you may be able to get engine power and vehicle weight information from the manufacturer.
If your car is modified, you may also need to obtain an engineer's certificate and do your own calculations. You are also required to notify VicRoads of any significant modification. Penalties for not doing so are severe.
If you are a probationary licence holder, it is your responsibility to make sure any vehicle that you drive is not a high powered motor vehicle. The penalties for driving a high powered motor vehicle include a heavy fine, and may result in licence suspension.
ok so based on factory specs of my car
February 1997 to 1998 > GTS25t type M active LSD specification
Engine Code RB25DET
Engine Type Water cooled Inline 6 cylinder DOHC 24 valve IC turbo
Engine Size 2.5 litres (2498 cc)
Max power 184kW @ 6400rpm
Max torque 294Nm @ 4800rpm
Forced Induction IC equipped turbo
Weight 1400kg
So:
184 / 1.4 = 131.42857142857142857142857142857
So yes according to factory specs my car would exceed power to weight rule.
But you could simply argue your engine is not brand new therefore those figures do not apply
Engine Code RB20DET
Engine Type Inline 6 cylinder DOHC 24 valve IC turbo
Engine Size 2.0 litres (1998 cc)
Max power 158kW @ 6400rpm
Max torque 265Nm @ 3200rpm
Weight 1320kg
So:
158 / 1.32 = 119.69696969696969696969696969697
So yes according to factory specs you can drive an r32 GTS-t Type M on your p plates.
But the same applies, the cops or dudes who check your car could argue that your pod filter allows 15% more air suction and capacity than the factory specs so therefore
158 / 1.32 = 119.69696969696969696969696969697 + 17.9 (<--- pod filter % increase) = 136
so therefore it is then over the power to weight, of course they have to be able to prove it and of course you need to have a pod filter that would make a 15% increase, which it most likely wont
i know it wont add 17kw, i was using the figures as an easy and bad example.
of course 15% more airflow wont give 15% more power, was just using it as easy comparison and figures. as if a pod filter would give that much more increase
  • 1 month later...
  • 2 months later...
As long as your vehicle runs the engine that it came out with, and its pwr to weight is p plate legal, according to OM specs, you can install all legal modifications and have "300kw at treads"(unlikley on legal modifications) and drive it on your p's
  • 1 year later...
Depending on who you're with I believe normally they just won't fix those items, they won't be covered by the insurance and they may reduce the amount of compensation but I can't imagine they would void the insurance.
They don't usually seem to have a problem with mods as long as you let them know of mods you make and their value so they may accordingly adjust your premium :)
Edited by Froozog
some victorian law.. :(
piggyback ECUs are referring to stuff like SAFC .. things which handle stuff your ECU normally handles.
also pod filters have to be boxed on most vehicles in most (or all?) states.. but you probably already knew that
Edited by hobbsy
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
