fuuark that, big cams are gay on a stock motor.. I would go big cams if I had a built motor, solid lifters, cnc ported head, blah blah blah and rev it's mum to 10k rpm witha  sequential box.
But nah.. it's a stocker heap of shit.
Goal: 400kW stock bottom end.
  • Like 2
mateeeeeeeee I love bunnings :)
Will be making a front splitter from marine ply.. will be solid, flexible enough and won't produce any "flutters" which can occur with shitty aluminium stance splitters. When there's enough air movement and it starts to flutter the entire splitter would rip off. Good explanation:
Flutter is a dynamic instability of an elastic structure in a fluid flow, caused by positive feedback between the body's deflection and the force exerted by the fluid flow. In a linear system, 'flutter point' is the point at which the structure is undergoing simple harmonic motion - zero net damping - and so any further decrease in net damping will result in a self-oscillation and eventual failure. 'Net damping' can be understood as the sum of the structure's natural positive damping, and the negative damping of the aerodynamic force. Flutter can be classified into two types: hard flutter, in which the net damping decreases very suddenly, very close to the flutter point; and soft flutter, in which the net damping decreases gradually
shhuuuuuuuuu baby, from what I gather the G3SAT will dose like a bawse  (from watching Jason Ferren's R31 Drift Wagon).
Brah plenty of brake fluid left ulleh, when ize put new pads in dat brake fluid will be le tits.
(brake fluid low because of worn brake pads and air in the ABS system from when I did the Brembo brakes up front, was full till I kicked off the ABS a few times then bleed some fluid and never bothered to refill it)
  • Like 1
7 minutes ago, admS15 said:
Maybe time for bw ts 8374? Will then be the ultimate le siet bok. Ultimate efames as well ulehemoji3.png
This guy... I agree with this guy!
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
