No real updates besides I am getting a new turbo setup and have bought a new N1 oil pump and moving my billet gears over to it. As of recent, brake light was always on too, turns out the "brake pedal stopper" snapped off so the switch wasn't pressed when the pedal was extended upwards. $11 part, coming soon, this is it btw:
There's a cheaper clear one for $4.40 vs $11 this is, but yeah might crumble again so went for this one.
No updates with the shit box, also note to all don't drive nice modern cars, you have even less reason to finish off your car lol.
Had a SQ5 for a week and wow, just wow. Fast, fun, comfy, no lag, stock (less things to break).
Took it on the beach too lol.
  • Like 2
Woah woah woah, I didn't say soft, I said changed.
I like me some stock daily comfort and wouldn't mind a euro as well.
Remember, I did opt not to buy an R35 because the M4 ways heaps nicer. I just ended up buying another house instead of swapping cars.
  • Like 1
Yeah hired car, it was so good.. And of course used launch control many times ?
Makes me want to flash the Tiguan and pop in a new downpipe/cat.
Also, I've been meaning to ask... You're changing turbo due not suitable for skid pan, but did you end up taking it to a circuit to see how it went? I thought that was the main goal?
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
