No real updates besides I am getting a new turbo setup and have bought a new N1 oil pump and moving my billet gears over to it. As of recent, brake light was always on too, turns out the "brake pedal stopper" snapped off so the switch wasn't pressed when the pedal was extended upwards. $11 part, coming soon, this is it btw:
There's a cheaper clear one for $4.40 vs $11 this is, but yeah might crumble again so went for this one.
No updates with the shit box, also note to all don't drive nice modern cars, you have even less reason to finish off your car lol.
Had a SQ5 for a week and wow, just wow. Fast, fun, comfy, no lag, stock (less things to break).
Took it on the beach too lol.
  • Like 2
Woah woah woah, I didn't say soft, I said changed.
I like me some stock daily comfort and wouldn't mind a euro as well.
Remember, I did opt not to buy an R35 because the M4 ways heaps nicer. I just ended up buying another house instead of swapping cars.
  • Like 1
Yeah hired car, it was so good.. And of course used launch control many times ?
Makes me want to flash the Tiguan and pop in a new downpipe/cat.
Also, I've been meaning to ask... You're changing turbo due not suitable for skid pan, but did you end up taking it to a circuit to see how it went? I thought that was the main goal?
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
