12 minutes ago, GTofuS-T said:
Also, I've been meaning to ask... You're changing turbo due not suitable for skid pan, but did you end up taking it to a circuit to see how it went? I thought that was the main goal?
I think I will be doing more skid pan days than track days coming up next year, the current turbo setup doesn't come on till 4300rpm (which isn't that bad for something potentially making close to 420~430kW). I was hoping to get the same level of boost threshold as my old billet Hypergear ATR43SS2 with this turbo however it doesn't. Also the transient on this turbo is much lazier than the SS2, then again this turbo's turbine side is essentially a GT35 where as the SS2 is a GT30.
My future goal is, early torque and early boost like my old SS2 setup but with about 420kW+, hence I've ordered (still waiting) a GTX3576R Gen 2 with a 1.01 divided rear housing.
  • Like 4
No real update, started car 1st time in 3 weeks. Started first go, still 20 seconds before it builds oil pressure.
Revved it a bit, dosed it a few times. Turned it off, next week will be going to my mate's shop and ripping off the sump and oil pump. Fingers crossed nothing catastrophic and only a cracked housing. Have a new housing to go back on with the existing Spool Import gears.
After that, maybe drop a set then back home to remove the turbo setup.
  • Like 1
  • 3 weeks later...
Happy New Year!
So some updates (no photos though, broke my "waterproof" phone when I jumped into a pool).
Removed sump, oil pump, oil pump housing to find that the innards were all scored and pitted as though something was ingested, however the sump and pick up appeared to be spotless.
Billet gears inside all damaged and just for a sanity check, decided to measure the tolerance between the crank snout (made by Spool Imports) and the Billet Oil pump gears and discovered a whooping 0.22mm tolerance each direction (not sure intentional). Have contacted Spool but they're off till the 14th of Jan.
Also got a call from Sparesbox yesterday and they're now (after 4 weeks) unable to supply me with the GTX3576R Gen 2, instead they've offered a GTX3582R Gen 2 instead, beggars can't be choosers so I said yes.
  • Like 2
Hoist life, seems like natural habitat for this sietbok.
A bit of skills involved but managed to remove sump, and oil pump with motor in the car ?
And yeah here's what billet gears looked like after I started having oil start up issues.
Sump, filter, pickup all clean. So must have been from the start I assume.
  • Like 2
  • Sad 1
23 minutes ago, ActionDan said:
Damn 0_0
The regret of not stripping the car and parting it when the original exploded was a big mistake and regret. I could be in a F30 335i at this moment talking about Stage 1/2/3 tunes using my phone and getting the latest cold air intake and yet lap a comfortable 1m8s around Wakefield with some decent tyres.
Oh wells, at least I have the Tiguan which ALWAYS delivers
  • Like 1
But when you get the better turbski and this thing delivers you'll have maybe 500 f**king kw to blast around with.
This is a track car, dont compare it to a daily with some bolt ons.
9 hours ago, ActionDan said:
What?!
I would never sell my tools lol
Only tools you need for an European car are a mobile, flash cable, and a good credit card.
  • Like 1
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
